| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
anyone running 50/50 WVO diesel mix without a conversion?
i've recently picked up a 1999 E350 PSD 7.3 super duty and am gonna convert it to WVO!! i have 2 mercedes i've already been running on grease for many miles and have a centrifuge and lots of super clean no water oil.... but,,, im getting impatient on putting my wvo system together for the PSD, and dont have the funds$ to get started ;( ... i want to do a Vegistroke style CV system, but cant afford it quite yet..... i've heard of a few folks running 50/50 diesel and wvo in their PSD's stock tank without a conversion... seems tempting, would be nice to at least half my diesel consumption - I am in los angeles, so its plenty warm this time of year, but of course, dont want to f-up my new ride!
my oil is centrifuged and then filtered again to 2 micron before going in the tank, so im not worried about dirty oil clogging filters, more worried about unheated wvo in the stock fuel system.... any thoughts? anyone doing it? |
Great solution for the older mercedes in warm weather, but I don't think it's a great idea on the PSD. I don't think the stock pump is burly enough to handle that, and there is lots of concern about what happens when cold oil goes through the injectors. Main worry is poor spray pattern that leads to coking. These conversions don't have to be fancy, but I would wait to WVO in till you have a fuel system set up for it.
From what I have seen and experienced its an ok idea but not for the stock pump. 50/50 is as high as I would go. Everyone looks at it as "thinning the VO with diesel" but in reality you are thickening the diesel with VO.
Some guys swear you can blend VO with D2 & others will scream at the top of their lungs that it will kill your engine. I have no personal experience with it but like Erbilabuc said you are thicking your fuel blend. Many guys are blending 80% VO & up to 20% RUG (regular unleaded gas) to reduce the viscosity of VO closer to diesel. Yes I said that right gas in your diesel. There are alot of guys running waste motor oil blended with RUG as well.
The only thing I can tell you is do alot of reading & then decide if you are willing to take the risk. I'm still on the fence about this topic. Your Mercedes would probably run just fine on a blend but PSD's are pricey to repair. IMHO this is the wrong site to discuss blending. Search other PSD sites & look for RSR911 & Jeffery S Brookes. They have alot experience with blending. |
wow, i;ve never heard of blending with unleaded gas! i think im gonna hold off on blending and just eat it with diesel til i get it converted.. get anxious to save more $ to do the conversion, but it would all be for nothing if i wreck the engine or fuel pump,etc
the old mercedes will run on 100% wvo in los angeles summertime without any conversion. i dont do it, but i know folks who do. on those cars its so easy to add heated injector lines, it ridiculous not to. you can covert a mercedes for $150 in parts, i originally had no idea converting the van was gonna take 25 times that! |
I run a 55% D2/ 40% veg / 5% RUG mix in my '02 f250 during the warm months of summer in WI. Runs just fine. My truck also has a full WVO conversion, but there's a lot of times in not partical for shorter trips so thats why I blend in summer. the RUG really thins the mix down and no negative affects. I have had no problems. I have run str. WVO & blends on my truck for the last 100K miles.
I'm curious: I'm gonna be pulling my injectors in the next couple weeks to replace them with stage 1's. I'm curious what they will look like. Not replacing because I'm having problems, more so as preventative maint. & an upgrade. Plus I've heard that the single shot will be much easier on my weak factory hpop. |
Ill probarbly catch hell for saying this but i dont care, I run used filtered tranny fluid in my 6.0. I put 5-10 gallons of tranny fluid and fill the rest with diesel. No issues whatsoever to date and the truck runs just a little smoother and I do lose about 0.2 mpg. As long as its clean and the ambient temp is relatively high running WVO shouldnt be a problem at a 50/50 mix.
Why is a single shot easier on your HPOP?? I didn't know they was a problem on the 7.3 other then they leak sometimes. |
The hpop in the 7.3L is barely enough for stock split shots inj under heavy load, after 200k miles the hpop gets weak. At this point I'm not willing to install a upgraded hpop as well. Now don't qoute me on this, what I'm told is that the single shot injectors don't use as much oil. I'm assuming this is because of the single injection event vs. dual(ie split). |
