| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
cf operation
can anyone post a video on a cf filter in action and go through the steps on how it works.....I have read on it but am more of a hands on person. I am thinking about buying one but would like a better understanding on how it works....thanks
thanks that was very helpfull now I just need to get one
good luck!
So I feel like doing a hijack
![]() But I guess this will be a bit on topic. I came on here tonight for the sole purpose of glorifying my lifestyle. I say life style because we ALL know that's what this WVO is. I had planned on singing the praise's of my CF..... So here goes, I'm piggy backing this thread. My truck has been running like a top with it's new heart transplant (fuel system) and I'm really happy with it. I just filled up another tank (on the truck) of VO this afternoon and now I'm making another batch of oil. All I do is turn on the air comp, turn on the heat, then power up the CF it's that simple. Good clean oil is being processed in my garage right now as I speak.I LOVE THIS!!!!!!!!! It is so awesome to be able to make ones own fuel, well not literally make it. But you know what I mean. My neighbor is always fussing over fuel prices and I just smile and nod as I tank up on VO. This is so cool. Post a PS: every thread deserves a pic |
That's a pretty sweet operation you got there, Aaron. Do you mind giving a little process flow explanation? Looks like you're using compressed air to feed your CF? How do you ensure your feed rate?
Yes, air pressure feeds my oil. I use the harbor freight drum pumps and run them at about 8psi.
I have 2 ball valves between my feed drum and my heater, they are used to regulate flow. It would be better for me to have a ball valve after the heater and regulate flow there. But i have not changed my setup yet. The process of heating, and the flow directions causes pressure to build up and sometimes I get erratic flow rates. Thus the need for regulating flow after the heater. I plan on going with a gravity feed system in the near future, using air to feed the CF requires more electricity -- more cost and there for higher fuel price. I originally used air so that I had a fully mobile system that could be taken on the road or moved to a different location. i have since found the right spot and will be soon making my cf a permanent fixture in the shop. I will still use air for transferring clean WVO throughout the shop because it is so simple and easy to regulate and there is no fear of damaging a gear pump or churning air into the vo. Anything else? Last edited by Aaron Berk; 05-25-2011 at 10:27 AM. |
