dual pump question - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 10 Old 05-12-2011, 09:46 AM Thread Starter
dual pump question
finally got a second pump. It's the WVOdesigns new pump.
Was using single pump with a 6 way valve to switch between tanks
Now gonna use a single pump for each tank.
Questions
When switching between tanks do you also switch power to the pumps?
Or are both pumps running all the time?
Thanks
GONEFISHINTODAY is offline
post #2 of 10 Old 05-12-2011, 09:51 AM
ridiculously_necessary's Avatar
i had mine set up with two relays. switch slected the pumps. i also had a bed tank attached to the veg pump so no switching was necessary, jsut had check valves in place.
if your using the stock tanks i assume you could just wire the pump switch to the tank switch.
been a while since we've seen you around here!
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #3 of 10 Old 05-12-2011, 12:17 PM Thread Starter
so do you get any lag or air when switching between tanks since only one fuel line is pressurized at a time?
Been a while. Got 45K mi using the stock fuel pump for both fuels.
post #4 of 10 Old 05-12-2011, 01:04 PM
nope, i wondered about that myself. nothing even remotely noticeable.
your not talking about still using your stock pump are you?
-Matt
DIY 6637
Marinco Mod
post #5 of 10 Old 05-20-2011, 07:10 AM
Aaron Berk's Avatar
I have both my pumps hooked up to a 3 position switch. Up is Veg, middle is OFF, and down is Diesel.
Then there are CV's in the engine valley, I don't get ANY lag what so ever.
My stock tank selector is now just a decoration piece.
97 F250 ext cab lwb 4x2
AirDog2 and FASS HD (it's a WVO RR setup)
Simple Centrifuge filtering method
203 degree Mod, DIY homegrown intake, CCV mod, battery relocation,
215amp Ambulance Alt.
EBPV gut, Pedestal gut & cut
Diamond Eye 4" (3" dp) turbo back straight pipe
no kitty, no muffler
Aaron Berk is offline
post #6 of 10 Old 05-20-2011, 07:34 AM
^ thats exactly my setup. no lag here either.
-Matt
DIY 6637
Marinco Mod
post #7 of 10 Old 05-20-2011, 08:30 PM
Quoted: 3 Post(s)
how are you guys flushing/purging the veggie oil with this set up. Im about to double down on my system also real soon. Im using a FASS pump for both sides but for another 200$ in materials im thinking of replacing all of my lines and doing dual pumps since I just hit 10k miles on veg and its celebration time.
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #8 of 10 Old 05-21-2011, 08:53 AM
Aaron Berk's Avatar
I only purge the components in the engine valley. When I switch to D2 I open a solenoid and flush every thing in the heads and fphe back into the WVO tank.
I don't purge my vo pump or TIH
post #9 of 10 Old 05-21-2011, 08:58 AM
Quoted: 3 Post(s)
does the solenoid bypass the vo pump? So this solenoid is energized open on vo and then it closes on D2?
Vegistroke V3.
post #10 of 10 Old 05-21-2011, 10:18 AM
Aaron Berk's Avatar
The solenoid when energized creates a looped return on the wvo side. The return flow of wvo tees into the supply for the wvo pump.
When de energized the fuel hits the ball valve on the d2 return. So if I ever need to return fuel on the d2 side I have to open the ball valve.
Both my pumps are self regulating with their own returns. So I can safely operate in a dead head style, or regulated return for either fuel source.
I like choice.
