| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
Tank heating
Ok, here is the next issue. I know...I have issues.
My tank. It is Aluminum. That is good. Problem is it is only 7" deep. It fits under my tool box perfectly, but is shallow. It is about 1/2 " shorter than the width of my bed and is about 3' in the other direction. 42 gal. tank I believe. Now, I am assuming it is baffled, will check on that later today. Would like to use a Hot Fox in it to heat, but they will have to shorten it if so because it needs a 1/2 " space and the shortest one they make is 8". Will that work, or should I just go in a different direction. One person suggested that I have a 4 to 6" hole cut out under the hot fox. Have a small reservoir welded in. This would give me a longer hot fox and help with air intake when the tank is low. (That is lessen the chance) I don't know, should I just get a different kind of heater and forget the hot fox? If so, what. Notice, I live in Fl. So the problem is not here, it is when I go North in the winter, which I do on occasion. |
Ok, I checked over lunch. The tank is baffled!!
The depth is 7 1/4". |
i have a 105 gallon L tank. i cannot use the last 20 or so gallons for the same reason.
if i had to do this again, i would go the resivour route. VegginPSD is doing that on his latest tank. I have and OBS, so with my truck i would like to use some sort of in tank heater, and use the drain plug with HOH and run it to the underbed tank, and block off the excape routes with some ball valves. this way i get the most out of my oil and two tank capacity. |
I thought the baffles were supposed to stop that from happening. I can tip the far end of the tank up a bit, but the more I do that, the more wasted space I'll have! |
the tank is baffled, but i cannot see them. i figure on hills and long curves the fuel will still slosh away from the hotfox. that and it doesnt go all the way to the bottom, i didnt install the brass extender. i too could tip it up, and may do that.
i think the baffles are just to keep the fuel from sloshing with a ton of force. |
aluminum needs special equipment to weld. send a message to vegginpsd, that who i will ask if and when i get around to this. i would think maybe look around for something thats aluminum that would work as a res?
Rather than welding, I imagine you could tap an outlet on the bottom of the tank to use as your fuel pickup. The same company that makes hot fox also makes an inline heater. You could use an in tank heat exchanger to get your oil warm, then use that inline heater to give the fuel going into your line an extra boost. BruceM, who posts here and at frybrid, put together a floating pickup to get around this issue. Check out his posts.
WVO designs has a hot stick (looks and works like a hot fox) that fits my tank just right. It is shorter than the shortest hot fox at 7". My tank is 7 1/4ish" and with a little extra washer material, I think it will work fine. Gonna find out anyway.
If it doesn't work, I'll look at the fab/weld option. |
