| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
Used engine oil as fuel ??
A "friend of a friend" says that he burns Used engine oil as fuel. Is this possible ? The kids dad owns a auto repair shop. I didnt go into detail with him because the kid i kind of an idiot. Just wondering if anyone could shed some light on this.
Thanks, Dave |
I know a Ford Service Manager who burns recycled transmission fluid in his 2001 7.3L Ex.
subscribed.....out of curiosity..............& welcome to the ORG
So he just puts it straight in with his fuel ? Doesn't seem like it can be good to me, but im new to this Diesel stuff. Is there a specific ratio ? Oil to fuel that is.
carefull what you say about running used engine oil on here they will get you
![]() ....yes you can run it but only thing I would do is filter it really good and mix it well with some diesel to thin and carry a set of extra fuel filters with you........just my $0.02 |
He has about a 75% transmission fluid / 25% diesel mix. At the dealership they do tranny flushes, the old fluid is filtered through the machine and he pumps it into his tank. I have followed him and on pulls it smells like a burning transmission.
. I run 100% W85 in my truck. I did a write up on this in the BioDiesel Forum, check it out hopefully it helps. The short is W85 is 15% RUG (regular unleaded gasoline) and 85% WMO (waste motor oil or whatever else tickles your fancy). You need to either build or buy a centrifuge to clean the oil, again check out the biodiesel forum for some neat CF builds. After you run the oil through the CF run it through a 3-5 micron filter and put it into your tank Good luck and let us know how your oil burning adventures go. |
This isnt the place to ask about it because it sounds so crazy but I've realized that people where against veggie oil at one point too. I think at oilburners.com is a good source for info.
Don't worry about spreaking about WMO/ATF etc. No rule against it that I am aware of. There are guys on here that are dead against it. They are entitled to their opinions but that should't stop people from talking about it.
You need to do more then centrifuge the used oil. Used oil can be acidic.
