Centrifuge motor - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 22 Old 04-11-2011, 08:55 PM Thread Starter
Centrifuge motor
I've been saving up to build a centrifuge, I'm going to begin with the poboy kit from Leon. I see that most motors are pretty pricey, but I was wondering if anyone ever thought about using the motor from a grinder, I can get a brand new grinder from harbor freight with a 3/4 hp motor, 3450 rpm, and 5/8" shaft for $45 with a two year warranty. I don't see why it wouldn't work?
mpiller is offline
post #2 of 22 Old 04-12-2011, 05:59 AM
ridiculously_necessary's Avatar
check your shaft length, thats the only thing that comes to mind. i was wonderinga bout this too.
i found a local motor being sold as used, but is actually new for $25. ill probbaly pick that up this week. in either case, i would like to know how a grinder motor would work as well...
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #3 of 22 Old 04-12-2011, 08:43 AM
Quoted: 3 Post(s)
As the product of a father that remanufactures a/c condensers and evaporators I can tell you that if it says 3450rpm then its not enough. 3450 constant rpm is max duty cycle for that thing and with weight of oil it will drop it down. If you can get a faster one then go for it since you are getting it so cheap anyways. Look into Grainger for references but thats all because their motors are super expensive chinese made.
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #4 of 22 Old 04-12-2011, 04:03 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Most centrifuges i have looked at are using the 3450 motors
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #5 of 22 Old 04-12-2011, 04:09 PM
Quoted: 3 Post(s)
Yep that would apply if MPiller was talking about the motor you are talking about but he is talking about the grinder model that has 3/4 hp but provides minimum torque. Bench grinders carry little torque in case you jam a piece of metal in the machine it doesnt burn up the motor fast and simply stalls without overheating long enough to either turn grinder off or dislodge the item.
does this make sense now? You really can stop a bench grinder with your hand if you are willing to sacrifice some cuts.
Vegistroke V3.
post #6 of 22 Old 04-12-2011, 04:48 PM
Hillbilly Deluxe
Quoted: 2 Post(s)
That makes perfect sense... The way your post reads it seemed you were saying that 3450rpms wasn't enough.
Seth
Stroked_NY_023
post #7 of 22 Old 04-12-2011, 08:21 PM Thread Starter
Ya I never thought about that. I guess I was thinking of my own grinder which takes quite a bit of force to even begin slowing it down, but then again its not a $45 grinder from hf. Thats the highest rpm one they sell, what if I set it up with pullies so that it spun 6900 rpm and if it lost a little it wouldn't be a big deal?
mpiller is offline
post #8 of 22 Old 04-12-2011, 09:18 PM
Quoted: 3 Post(s)
sure, anything is possible with a little science. It will take a tiny little bit to get it going but once its going it will be good.
Vegistroke V3.
post #9 of 22 Old 04-12-2011, 10:05 PM
Aaron Berk's Avatar
Once you start adding pulleys and belts your vibration will increase. Which isn't a good thing when spinning the nasty stuff.
I would be more inclined to wait and find a higher hp motor for the right price.
I've heard ALLOT of stories of off kilter vibrating disasters with oil centrifuges.
Find your self some junked up old woodworking machines with 3hp 220v motors
And post your location
97 F250 ext cab lwb 4x2
AirDog2 and FASS HD (it's a WVO RR setup)
Simple Centrifuge filtering method
203 degree Mod, DIY homegrown intake, CCV mod, battery relocation,
215amp Ambulance Alt.
EBPV gut, Pedestal gut & cut
Diamond Eye 4" (3" dp) turbo back straight pipe
no kitty, no muffler
Aaron Berk is offline
post #10 of 22 Old 04-14-2011, 11:12 PM
You're mistaken. You're saying that removing a direct-drive, rigid-mount, high-rpm hard shaft coupling will have less structural vibration than a system that offsets the motor from the final drive shaft by means of pulleys on bearing shafts, and power transmitted via a belt? Ask yourself, why did some motorcycle manufacturers opt for belt drive systems over shaft or chain, which are inherently more durable?
I think you'd better pick up a high school shop text and start reading.
Couldn't agree with you more.
Yes, a rigidly mounted motor of this rotational velocity and power will certainly induce quite a bad vibration if forced to spin something that is not properly balanced.
Exactly. My table saw uses a large 3450 RPM motor... connected to the blade shaft by means of a belt. Not only does it make for good power transfer, it also reduces vibration. Yes, I'm sure SOME power and torque is lost in the process, but given that I can put a 2" thick plank through it at a good clip, I'm not terribly worried about it.
My system WILL have a belt drive.
ekfinn is offline
