Why does vegetable oil get foamy? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 20 Old 03-27-2011, 09:56 AM Thread Starter
Quoted: 3 Post(s)
I'm guessing old and a lot of water? I googled but came up with a bunch of stuff for cooking. One of my restaurants called me up to pick up oil. Got it home and all I can see after taking cap off the cubies is foam and a gross smell. This guy owns another restaurant about 100 miles away so Im thinking this could be old oil he was saving for someone that never showed up to get it (the reason I pick up his oil now).
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #2 of 20 Old 03-27-2011, 10:07 AM
simone0414's Avatar
Does it smell like puke? Have you checked with the restaurant to make sure it doesn't have boilout in it? It's probably not that though but can't hurt to ask.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #3 of 20 Old 03-27-2011, 11:29 AM
Aaron Berk's Avatar
I've gotten oil that had just a little foam on the top, but nothing major.
I've never seen the foam reappear after settling and centrifuging, but what causes it? I have no idea, I'd guess it has something to do with what they cook or clean with??
97 F250 ext cab lwb 4x2
AirDog2 and FASS HD (it's a WVO RR setup)
Simple Centrifuge filtering method
203 degree Mod, DIY homegrown intake, CCV mod, battery relocation,
215amp Ambulance Alt.
EBPV gut, Pedestal gut & cut
Diamond Eye 4" (3" dp) turbo back straight pipe
no kitty, no muffler
Aaron Berk is offline
post #4 of 20 Old 03-27-2011, 12:40 PM Thread Starter
Quoted: 3 Post(s)
hmm yeah it smells like sweet vomit if there is such a thing. Im wanting to throw it away....thoughts?
Vegistroke V3.
post #5 of 20 Old 03-27-2011, 01:01 PM
simone0414's Avatar
Its starting to go bad. How much of this stuff do you have? Do you have good stockpile of oil? If so I would turf it. If not you probably could use it as long as its not too far gone. I have burnt oil that smelled bad with no problems. But if its really bad I wouldn't chance it.
post #6 of 20 Old 03-27-2011, 01:05 PM Thread Starter
Quoted: 3 Post(s)
I have over 300 gallons of oil on reserve so this 30-40 gallons isnt going to hurt me. I think I did the guy a favor by taking it from him. He had another guy who he used to give it to and he said about 6 months ago the guy stopped showing up to the restaurant that is like 80-100 miles away so I think this might have been from that. I will ask him next time I see him.
Vegistroke V3.
post #7 of 20 Old 03-27-2011, 03:53 PM
simone0414's Avatar
To be on the safe side I would get rid of it. I would put an add on craigslist. Maybe someone can make bio out of it.
post #8 of 20 Old 03-27-2011, 06:32 PM Thread Starter
Quoted: 3 Post(s)
found out what it is. Its flower thats been broken down to pure starch.
Vegistroke V3.
post #9 of 20 Old 03-28-2011, 02:24 AM
simone0414's Avatar
How did you determine this? If it smells like puke it is starting to go bad though. Perhaps it is being way overcausious to say throw it out because chances are that it will burn just fine. Maybe you could mix it in with some good VO & burn it.
post #10 of 20 Old 03-28-2011, 05:07 AM
Snake's Avatar
Quoted: 47 Post(s)
If it smells like puke, don't use it.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
