| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
NEW TO BIO WITH TONS OF QUESTIONS??????
My best friend has a 7.3L powerstoke the other day he started talking about running V.O. in his truck so he got some used oil from a friend of ours resturant filtered it threw a 5 micro filter & mixed it with regular diesel fuel from the pump & drove off I havent heard from him yet to hear how it worked but does anyone know if thats a good idea to do. Also I have a 2005 6.0L that I would like to start running this mixture in it but want to make sure this is a good idea first? I have tryed doing resource of this but everything online I find is people mixing the oil with methonal & other chemicals before running it n there trucks. So all Im looking to do is filter the crap out of the oil & mix it with regular diesel fuel is this a good idea or bad idea???? And does anyone know if Im safe doing a 50/50 mix or should I do less or more???? TIPS AND ADVISE PLEASE!!!
no. bad idea.
the methanol thing you mention is actual biodiesel conversion, which is perfectly fine however. it is a bad idea to mix. the proper way is to run a conversion kit. start on diesel to warm up, run vo, and stop on diesel to flush the fuel system of the vo. the vo is put in a second coolant heated tank to reduce viscosity. there are numerous accounts of damage from mixing the two and cold starting and idleing. you can however mix D2 and VO in a heated tank. some people will tell you its ok, some dont ahve issue. or at least not yet. |
Agree with above.
If you're going to do this, either make biodiesel and blend that with your diesel or make/buy a conversion kit and run svo. You're playing with fire if you don't. Furthermore, simply running vo through a bag filter isn't nearly enough to make it safe to run. There's a good reason that people are spending hard earned money on equipment to filter and dewater their oil. |
I thought it was possible to run on V.O. mixtures without doing a complete "conversion" which is what I was thinking. So is there a way to run off V.O. with out having to do a seperate tank & lines & switches or no?
ok thanks snake I found another website that helped exsplain this alittle better to me than my friend did. I was thinking that biodiesel was V.O. & diesel mixed but biodiesel is actually the methonal & other mixtures mixed with V.O. & then mixed with diesel & then put threw the truck. CORRECT????
you are correct sir!
the only proper way to run VO is with a conversion. you can blend any amount of bio with D2 you want, or just B100. |
There are some engines that you can mix SVO with D2 & dump it in your tank & go. Your 6.0 is NOT one of them. If you value your engine & don't want to empty your pocket book fixing it then either make bio or put a second tank system in & heat the VO.
Your driving habits will determine which way to go. Have alot of short drives ( 10-20 k miles or less) then bio is for you. Alot of longer drives then I would strongly suggest going SVO. Bio is a pain in the but to make IMHO & requires the use of dangerous chemicals to make it. With SVO you filter & dewater it by heating settling or centrifuging Dump in your heated conversion tank system & your done. I prefer centrifuge over heat & settle. Before you do anything have you found a source of VO? That's the first thing you need to do. Everything else doesn't matter if you can't get any oil. |
