FPHE ?? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 16 Old 03-20-2011, 06:26 PM Thread Starter
kevinj1's Avatar
FPHE ??
How many plate FPHE do I need for my truck? and do I need to add a coolant pump to my system with the FPHE?
Thanks Kevin
Central, New York,
'02 F350 XLT CC,SB,Dually 4x4 7.3L auto 143K mi.
ZooDad, NAPA 6637, '08 Mirrors, DIY WVO system
Towing 2011 Flagstaff 8528BHSS
Truck & Trailer GCVW 18980 Lbs 6/20/2012
kevinj1 is offline
post #2 of 16 Old 03-20-2011, 07:17 PM
Quoted: 3 Post(s)
In NY I would go with 30 and up since you see cold azz winters. Coolant pump I have no idea about.
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #3 of 16 Old 03-21-2011, 06:23 AM
ridiculously_necessary's Avatar
coolant pump is not required but is advised. i would do one...
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #4 of 16 Old 03-21-2011, 06:48 AM
tubular031's Avatar
the biggest you can fit in the location you chose Some say FPHEs are not required and some will not run without one. some kits run many miles with a tiny heat exchanger and work fine. The 7.3 is an amazing setup in so many ways! The colder it is around you the bigger I would make fit.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #5 of 16 Old 03-21-2011, 01:31 PM Thread Starter
kevinj1's Avatar
Thanks guys
Central, New York,
kevinj1 is offline
post #6 of 16 Old 03-22-2011, 08:41 AM
tubular031's Avatar
If you are in the market for one check out omarsales.com. I just bought my replacement from him and he is very fast and a good guy to deal with. Oh and what he says is actually what shows up in the box! Not like the mess I got into with another vendor and the reason why I have that goofy tinker toy setup under my truck right now...
post #7 of 16 Old 03-23-2011, 01:19 AM
simone0414's Avatar
The more heat the better. I would go with the coolant pump & get at least a 20 plate FPHE. Insulating your VO lines helps alot as well.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #8 of 16 Old 03-23-2011, 03:43 AM Thread Starter
kevinj1's Avatar
I have a 30 plate on the way, Dudadiesel had a good $$$. Do I put the coolant pump on the supply to the VO system or return?
Thanks Kevin
Central, New York,
kevinj1 is offline
post #9 of 16 Old 03-23-2011, 05:15 AM
Aaron Berk's Avatar
I've got my coolant pump mounted next to my fuel tank, on the return side of my coolant loop. I did this so that I don't risk a melt down.
I think it was Clay who mounted his in the engine bay as the first component on his supply line. So it saw maximum heat and caused it to fail. If I remember Correctly.
I didn't want mine to melt like his so I put it under the bed in line after my HotFox. I don't yet have my system up and running so I can't report the results from having it in this location yet.
97 F250 ext cab lwb 4x2
AirDog2 and FASS HD (it's a WVO RR setup)
Simple Centrifuge filtering method
203 degree Mod, DIY homegrown intake, CCV mod, battery relocation,
215amp Ambulance Alt.
EBPV gut, Pedestal gut & cut
Diamond Eye 4" (3" dp) turbo back straight pipe
no kitty, no muffler
Aaron Berk is offline
post #10 of 16 Old 03-26-2011, 07:43 PM Thread Starter
kevinj1's Avatar
I got my Mercedes circ pump from parts geek. it must be meant to be an oem replacement so it had no plug connection for power does anyone know were to get the plug from?
Central, New York,
kevinj1 is offline
