Artic Fox Heat Exchangers Advice? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 03-20-2011, 05:25 AM
I have a 26 pfhe but I just stumbled across the more eye appealing Artic Fox heat exchangers. Can anyone give me any advice as to wether or not they are a good investment as I am looking to replace my 26 plate if performance is around the same.
Old 03-20-2011, 07:11 AM
Are you talking about these?
In-Line Fuel Warmers
Old 03-20-2011, 08:23 AM
yes thats the ones.
Old 03-21-2011, 03:51 PM
Well no one else has bit on this, so I guess that might be a hint.
I'm thinking none of us have used em, or know any one who has.
I've got a HotFox fuel pick up in my truck (as do allot of us), and it's 100% awesome. I wouldn't think twice about using one of their other products either, if I was so inclined.
If it tickles your fancy, go with it. The company has been around long enough I'm sure its a good quality product.
I would only be concerned with the max tep they can transfer. If you can talk to them and find a product that transfers enough heat into the fuel, go for it.
I doubt you'd be disappointed.
Just my .02
Old 03-22-2011, 04:34 AM
whats the price compared to an FPHE? also, how much surface area does it cover compared to an FPHE?
Old 03-22-2011, 05:09 AM
26 plates are around 100$ with copper brazing but the artic fox are all stainless from what I read. I dont know about contact area since thats why I asked.
Old 03-22-2011, 06:22 AM
just knowing its not copper, and its by Arctic Fox would be convincing enough for me to try it. provided its not too much more expensive anyway. hell i dont have an fphe yet, i may just do that.
EDIT: this states .5 gpm max flow rate. for those of us with a reguated return i would like to see % in degrees rise at various flow rates and coolant temps. and can it be on the pressure side? i would think so?
http://cgi.ebay.com/ebaymotors/Arcti...Q5fAccessories
Old 03-27-2011, 06:07 PM
Send a message via AIM to muns53
BruceM is using one of those, I think. He likes it pretty well. All stainless as opposed to the copper (or nickel) brazing in the ends of the FPHEs.
Old 03-28-2011, 02:36 AM
Even if they are more expensive if they have no copper in them they probably are worth it. I have a Hotfox in my tank & it is a great product. All stainless, good construction & provides very good heat transfer. We have seen many reports of FPHE's polyed up so this may be the soultion.
I would call Artic Fox & ask them about it. If it provides heat transfer like their HotFox does then I'm sure it will work just fine.
Old 03-29-2011, 11:35 AM
I found some good specs from Arctic Fox. This link shows temps going in and temps going out of their inline heaters.
http://www.arctic-fox.com/pdf/Data_S...el_Warmers.pdf
It would be really helpful if someone with a FPHE could give us some temps on their oil going in and coming out. I think you could do this in a matter of minutes with one of those hand held temp guns. I am seriously considering one of these because of the all stainless steel construction. I wouldn't mind paying a little more if I know I can get the same performance as a FPHE.
Thanks to anyone who does post their temps. That would be really helpful.
