Drowning in Poly, my worst nightmare - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 02-24-2011, 12:33 PM
Drowning in Poly, my worst nightmare, now with pics!
So my truck has been coughing and leaking lately. Leaking fuel just to be clear.
I've got a new fuel pump, the one in the valley, and a hand full of 0-rings.
I'm pulling stuff apart and OMG my valley is a gelatinous blob of poly goo
I'm tearing into my truck today, like in the last 30 min
My fuel bowl has tons of POLY, and a the remains of a broken filter in it. The filter was from the PO of the truck.
I never drained the bowl or checked in there till now
There is poly EVERYWHERE up here in the valley, in the bowl, in the lines, in the banjo.........
And I have pics of everything. They will be up tomorrow.
Somebody pray for me, I'm going back in.....
Last edited by Aaron Berk; 03-04-2011 at 07:18 AM. Reason: Added a pic of my fuel bowl, filled with polly
Old 02-25-2011, 06:40 AM
why is there poly in your factory fuel bowl? Easy way out is to ditch all the lines right now and replace them with good year rubber lines.
Old 02-25-2011, 07:52 AM
youve been running veg a long time iirc. so you saved some money! minor setback here, good luck. i think you mentioned budget was a problem, so start saving for electric conversion!
im nearly done with mine, i plan on posting the conversion after i finish, all thats left is bowl and pump removal.
Old 02-26-2011, 09:21 AM
Good news guys, funding has been approved. And credit card numbers released
I'm going all out on this one
I might even take it as far as a new titan tank. Maybe......
Right now I'm gathering a parts list, and will be going full electric, and modeling it much like yours Ridiculous, almost exact. you drew up a good plan.
I'm thinking about using an Airdog system for the diesel, and a WVODesigns pump on the veg side.
Any thoughts on the air dog?
And Ridiculous, do you have any drive time on your set up yet? I haven't followed you close enough, but I knew you were on the verge of completion.
I will be reusing my Racor1000 on the veg, but relocating it to either the engine compartment, or under the bed with an access door.
I'll add in a Mercedes coolant pump, mounted on the return side, close to my fuel tank, switched so it only operates when on veg.
I'm debating the thought of 2 FPHexchangers, one in the valley, and one before the Racor.
I'm pumped about finally building my truck right, the shared fuel bowl design from the GoldenFuels kit was a total flop, the PO of my truck should be
But I got my feet wet, and learned allot. So...... Now we'll see if I actualy learned it right
Old 02-26-2011, 09:25 AM
My conclusion is incomplete purge cycles, the shared fuel bowl design of my current conversion set me up for imminent failure.
Drowning in Poly, my worst nightmare-dscf7339.jpg   Drowning in Poly, my worst nightmare-dscf7338.jpg
Last edited by Aaron Berk; 03-04-2011 at 07:17 AM. Reason: Added pics of the vally, and the polly I dug out of it
Old 02-26-2011, 10:48 AM
ok ditch the Air Dog, I think I'm going Fass.
To be determined......
Old 02-26-2011, 07:00 PM
Ok, Airdog is on order, on to the next item....
Old 02-26-2011, 07:31 PM
go with FASS if its going to be for veggie oil.
Old 02-26-2011, 08:11 PM
The airdog will be my d2 pump, I'll be using a wvodesigns pump for my WVO.
I'm now trying to find the "perfect" FPR.
Old 02-26-2011, 09:04 PM
Anyone have opinions on this fuel lab regulator?
515 Series - EFI -10AN inlets -6AN return
Here is the other one I like, it offers a higher flow capacity. But I'm wondering if it's over kill by a long shot?
http://www.maperformance.com/fuelab-...tor-56501.html
