| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
pics of your pump mounts
I got the new pump from wvo designs. Thing is heavy(10lbs) and big.
Would like to see pics of other installs to give me ideas. It's gotta be beefy cause this pump has some good torque on initial startup. I plan to mount the pump along with an inline fuel filter. thanks |
You want pics of any pump install or wvo designs specifically? If you have an aftermarket air filter you should have room in the left (as you are sitting in truck) wheel well to make a bracket. Thats where I have my FASS and it weighs 12 pounds.
erbilabuc
I would like to see pics of your pump too, Or anyone else who has found space other than the frame rail. I am trying to locate mine were the winter road salt and crap can't get at it Thanks Kevin |
im in the middle of making a metal bracket but mine is temporarily in my left wheel well next to fuse box. I will get pictures in the morning.
i just mounted mine yesterday, it not the best job i the world as i am limited on tool and next to zero fabrication expirience. but ill take a pic and post it.
if you pm your email, i'll send you pics of the bracket i fabbed up. The interface here sucks for posting pics. However, mine is a frame rail mount. I mounted it right behind the transfer case. Protected from hits, but not from road grime and such. Before, I mounted it in the front corner of the bed. that worked well and was well protected from everything.
