Simple question about fuel line - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 01-25-2011, 05:41 PM
Do you guys think 3/8" fuel line (fuel injection hose, J309R) will be large enough as a main feed from the wvo tank. The engine is stock right now and the most I would ever do is maybe reprogram the computer and put an exhaust on it. Thanks.
Old 01-25-2011, 06:00 PM
What kind of return, if any are you running.....i.e deadhead (none), return to tank, or return pre pump?
Deadhead- 3/8 should be fine
Return to tank- 1/2 inch would be better
return pre pump- 3/8 will be fine.
I feed my stage 2 Casserly's with 3/8 OD aluminum HIH with the regulated return pre-pump. Even with hot tuning, I get ample fuel to the VO Fass. FWIW.
Stock injected trucks should be fine with the above recomendations.
Old 01-25-2011, 06:51 PM
Thanks vegginpsd, I'm going to be running a regulated return pre pump.
Old 01-25-2011, 07:06 PM
You will like the RR!
Shuts the injectors up nicely and gives peace of mind they are fully fueled.
