| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
fass hdfp installation
Ok well I wasn't real sure where to put this so I hope this is the right section. I have a greasecar system installed on my 2000 f250 and it has been doing good but I knew that I wanted to replace the stock pump with something better, and I found a good deal on a fass hdfp so I bought it. Installation wasnt that difficult and I added a fuel pressure gauge to watch the pressure, had to tighten the spring a bit but the truck started right up and ran great with a consistent 65 psi. Drove the truck for only about 10 minutes because it was late when I finished but when I pulled back into the driveway the truck just died. Wasnt sure what it was but I kept messing with it and you could start the truck up and it would run but it would just randomly die, and when it died it wasnt like it ran out of fuel it just immedietely died like I cut it off, and it never sputtered or acted like it ran out of fuel. To me it sounds like an electrical problem because of the way it was cutting off, but I just connected the stock pump wires to the connector fass provided. The problem now is that when you turn the truck on the pump will turn on and put out about 10psi and then the pump will cut off after about 30 seconds. Any ideas what could be wrong?
Thanks |
Not sure what the problem might be. I have the HD also as my fuel pump. I do know that when I had it installed they wired it from the battery and didn't use the old fuel pump wiring.
Ok I'll have to try that. How could I wire it to the battery and have it turn on with the truck?
Well I wired it to the pump and got the same thing, about 10 psi but this time the pump would run continuously instead of cutting off after 30 seconds, and the truck wouldn't crank on 10 psi.
A 30A relay is required to operate a fass pump correctly and long term
Use the factory power source as the trigger for the relay, while using 12 AWG wire with an inline fuse rated for 30A. Ground the pump to the battery. The pump will run the same as the stock pump did using the factory lead as the trigger in respect to shutting off after key on/engine off. |
did you fix this? are you pulling oil from your filter or pushing through your filter?
This is a fuel system. The pump is now the only pump, stock not being used. Pulls from the tank, through the FASS and the to the fuel bowl on top of the engine.
Polarbear: he has a greasecar kit so this is not the way greasecar kits are set up or really any other grease set up.
Well for now I went back to the stock pump until I have a day to install it. And it is set up to pull through the filter.
Could you please describe your Vo conversion & how it is set up. I am unfamiliar with how a greasecar system works but if I an understanding you correctly you are running your fass for D2 & VO & you stock fuel pump is not running anything. If this is so then I would be concerned about that. IMO the best way is to leave your diesel fuel system the same & run a whole new fuel system for Veg. Copying the Vegistroke conversion by using the plugged ports in the heads for the VO fuel lines & not messing with the stock fuel bowl is the way to go IMO.
Do you have a FPHE in your conversion? What veg temps are you getting? I have heard many times that greasecar systems do not provide enough heat to run veg at proper temps. As for the Fass itself I think vegginpsd is on the right track. The Fass requires 30amps & I am pretty sure your stock wiring setup is for 20 amps. Your probably not getting enough power to run the Fass. Are you blowing your stock fuel pump fuse? Are you getting any codes? |
