| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
Super Sucker Tank help
So I scored my first big supplier which will equal over 100 gallons a month. I have this square steel transfer tank thtat holds 105 gallons. Do you guys think I can pull a vacuum on this tank without collapsing it? The tank is pretty much setup for it already with the ball valve and I just need to find the vacuum pump and the gauge. If I cant pull a vacuum on this tank then I am going to buy a small cheap trailer and mount it on there with a trash pump and that will be my source.
I believe that every vacume tank that I have ever seen was round and also every pressure tank was round. By round I mean "diameter" like a LP tank. I think that anything else would not hold up.
im inclined to agree. i would keep that nice tank you haev and find an old propane tank to stick on a trailer.
thanks for replies. Im just going to strap this tank to a small trailer and buy a trash pump.
have you taken a look at those monster gear pumps?
edit: ok just googled it and for 500$ it would not work for me. A trash pump is what I need since its gas driven. |
Don't waste time pumping, high speed self priming gear pumps
tubular031 has one and loves it. a few others here have one as well. i have no idea what they cost in comparison to a trash pump, or what kind of power they need - like if an inverter will work. |
If I was still having to pump oil to collect, i would not still be doing this. Way to messy.
Make a couple collection barrels like mine and set them out back of the place. |
how do you get it out of collection barrels? I am going to have a small 105 gallon tank with trash pump to suck oil out. I dont see how it can get any cleaner then that? Is your truck 08 or 06? I thought you had an 06...I ask because there is a guy that came up to me today with an 05 6.0 that wants to convert.
Vegi oil collection barrel idea I have a 2008 6.4 and a 2003 6.0 Last edited by Clay Henry; 12-17-2010 at 04:32 PM. |
