| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
Front cover rocks!
We started to have some cold mornings here and my switch over times were 7+ miles. Not good.
I went looking for a front cover to try to help my truck warm up faster and keep warm in slow traffic. This thing works very well and it looks better than any goofy thing I can build WF922-7 | Fia Vinyl Grille Winter Cold Front & Bug Screen Combo It also comes with a screen for summer use to keep the bugs out. There are 2 little windows on the front that can open and close very easy. The other morning it was 38 when I left my house and I was switching over (at 170 coolant and 155 ish EOT) in 3-4 miles! Before that would be 8 or so miles. Next big thing this cover did was help keep my truck warm when we get into heavy traffic. when its less than 50 out I will drop down to less than 160 EOT really quick in the slow morning crawl. with the cover on I have yet to see anything below 170 EOT even in the slowest traffic. Install is simple. The snaps are peel and stick. I am going to put some screws through the 4 corners soon just to be safe. I have run this cover with the 2 windows open (running empty) at 75 degress out and the truck runs fine. It will hang at about 195 to 205 EOT. If it gets much hotter I would take the cover off. Removing it is also simple, just pull it off and the stick on snaps stay in place. ![]() ![]() Here is the screen, you get the idea... ![]() the only down side is my girl says my truck looks lame now. she says it looks like I am playing dressup with my truck
I have one on my truck too. Once i put it on the truck warms up quicker with hotter heat!
That looks pretty much the same as what I have. I need to get mine on soon as well. Getting cold here as well.
what is the cost of one of those. I am seeing drops of 160 degrees to 140 in less then 2 minutes. Im going to wrap my heat exchanger in insulation also to help out.
ok just saw link |
its hard to find one for the OBS. i found one once but cant seem to again.
I ordered mine from these people Alaska Tent & Tarp :: Vehicle Grill Covers
Great to work with...I will have it next week. I hear good things of their quality. It was $70 to my door. I will let y'all know how it is. |
Before I order one here is a question: my radiator sticks down past the bumper so is this cover going to be enough just by covering the grill area?
I had mine made for $30 bucks. It has a zipper down the middle for adjusting air flow. I had a local canvas shop make it for me. Its basically the same one as the alaska tent and tarp one. I bought one from them before and it was great but too much money.
I drove home from work the other day and it was 81 out. I left the cover on just to see what would happen. I opened the 2 vents and saw 209 max EOT. Not too bad. I would NOT tow ANYTHING with the cover on. but empty with the windows open you can run it up to 80 deg. |
Well I dont have time to order one so me and my wife decided to make a template out of cardboard and cover it with some walmart 3$ cardboard. Did a test run tonight and got Engine coolant to 190 degrees and veggie oil to 120 degrees in about 3 miles which is not bad considering it 35 degrees outside.
