Suggestions on FPHE and electric line heaters - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 5 Old 11-19-2010, 03:13 PM Thread Starter
Quoted: 3 Post(s)
My switchover times right now equals to about 8 miles at 70 degree weather. I know I need a FPHE because my oil hovers right at 160ish at its hottest. I would lso like to add something like a vegtherm injector line heaters possibly. Any suggestions and if so any pictures of where your FPHE is mounted?
thanks
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #2 of 5 Old 11-20-2010, 06:53 AM
I would not recommend a veg therm. I ran one in my truck for awhile and the poly buildup is significant. If you choose to run one, make sure you put it prefilter to catch any poly chunks and plan on pulling it for maintenance every six months or so.
I installed my FPHE in the engine valley. I pulled the stock fuel bowl and mounted it vertically on L brackets using the bolt holes for the fuel bowl. Works great and the fuel goes straight into the front ports from there.
'96 F-250, 230k
Custom SVO Conversion (check valves)
On board filtration
80k SVO miles and counting!
CharlieC is offline
post #3 of 5 Old 11-20-2010, 07:28 AM Thread Starter
Quoted: 3 Post(s)
wow good to know about vegtherm. Any pictures of your FPHE and where did you buy it?
Vegistroke V3.
post #4 of 5 Old 11-20-2010, 10:23 AM
Sure thing. Here is a link to pics of my FPHE install. I purchased it from Rover Hybrids. Get the biggest FPHE you can and insulate it. You won't regret that choice.
Electric fuel system upgrade on veg conversion.
'96 F-250, 230k
On board filtration
CharlieC is offline
post #5 of 5 Old 11-22-2010, 10:36 AM
tubular031's Avatar
I used one from omar on a friends truck. Much better than the stupid one I have.
O m a r S a l e s
If and when I need to replace mine ill get one from omar also. I like the idea of putting it in the valley.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
