40 gallons of really nasty centrifuged oil - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 10 Old 11-18-2010, 07:21 PM Thread Starter
Quoted: 3 Post(s)
this is what I got after CF'ing for 2 hours at 130 degrees. cleaned it out then ran it again for another hour and got some really nasty gritty stuff. I cant believe I was even considering a regular filter. I bought this CF setup from a guy in Vegas that was moving for 250$. The bottom is banged out to a cone shape and it has a 110v heater at bottom. Dishwasher motor with an acura integra power steering pump. I was grossed out a little when I started cleaning out the CF with my finger.
[IMG]http://i690.photobucket.com/albums/vv264/erbilabuc/Biodiesel%20for%20my%20F350/IMG_0467.jpg[/IMG
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #2 of 10 Old 11-19-2010, 07:15 AM
ridiculously_necessary's Avatar
that looks like either water contamination or PHO. did your source switch oils on you? ahve you verified your 130* temp to be sure your element is working properly?
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #3 of 10 Old 11-19-2010, 07:21 AM Thread Starter
Quoted: 3 Post(s)
Yeah the oil I get has a little HO in it so to get it out I settle my oil for 2 weeks then run the centrifuge cold for 30 minutes and that builds up and then I heat it up. Yeah I have a thermometer on the outlet of my CF.
Vegistroke V3.
post #4 of 10 Old 11-19-2010, 01:50 PM
tubular031's Avatar
If you heat up that sludge does it turn liquid? a good example is lard. its solid at room temp but heat it up and it turns liquid and you could burn it in your truck if you can keep it hot enough.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #5 of 10 Old 11-19-2010, 02:01 PM Thread Starter
Quoted: 3 Post(s)
yeah it turns to liquid but I dont trust it because it was around 65 degrees last night when I took that picture and it was pretty solid.
Vegistroke V3.
post #6 of 10 Old 11-19-2010, 02:02 PM
tubular031's Avatar
Its probably fats or lard. Did this oil come from chicken fryers?
post #7 of 10 Old 11-30-2010, 12:07 PM
E'sStrokr01's Avatar
So are you going to continue using the oil?
E'sStrokr01 is offline
post #8 of 10 Old 11-30-2010, 12:14 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Melt it, centrifuge it and use it. Thats chicken fat if i have ever seen it.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #9 of 10 Old 11-30-2010, 12:23 PM Thread Starter
Quoted: 3 Post(s)
yeah Ive been using it but it was weird since my oil was at 110 degrees and it still built up like that.
Vegistroke V3.
post #10 of 10 Old 11-30-2010, 12:32 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
If memory serves me, it takes about 120* to melt it. My oil all has a few inches of that at the bottom of the cubies.
