How many miles on your svo conversion? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 09-27-2010, 11:38 AM
I am considering doing a svo conversion on a 99 psd. Has anyone been running svo for over 100k or 200k miles. I am concerned about the long term effects that svo will have on an engine. If you are running svo/wvo in your truck can you please post how many miles/years you have been doing it for. Thanks.
Old 09-27-2010, 11:47 AM
vegginpsd is your man! he will post soon...
they key to longevity is converting properly. your in the right place!
Old 09-27-2010, 11:48 AM
44k miles on WVO in the past 26 months. Truck is a 2005 F-250 with 144k miles on it.
Old 09-27-2010, 04:06 PM
45 k over 24 months on a '96 PSD.
Old 09-27-2010, 09:08 PM
26k on my 2001' X at 120k now.
~20k on my 1984 F-250
Old 09-29-2010, 11:58 AM
SkySkiJason has 130k or so in the past couple years. He does not post on this forum.
I am about 36k now and 18 months.
The key is to do it right. Start the truck on diesel, switch to HOT oil and purge the oil out with diesel at shut down. The second key is good clean oil. you WILL NOT get this with filters..... you NEED a CF.
Old 09-29-2010, 12:01 PM
I don't want to argue that a CF is better than a still, but there are a lot of folks out there who successfully used a still for a long time. I believe Clay used a still for over 90k miles before going to a CF.
Filters without a water heater is a different story.
Old 09-29-2010, 12:14 PM
vegginpsd has over 100k.
Old 09-29-2010, 01:09 PM
119K on the same injectors and havent touched the heads. (my F350)
100K on the 03 Jetta
130ish K on the GF's dads F250
I removed my stock injectors a couple weeks ago for Stage 2's.......They looked and performed GREAT! I would re-install them in a minute.
Here is the secret:
1) 160*F minimum before the fuel ENTERS the head.
2) DRY oil
3) Clean oil
4) #2 & #3 cannot happen without a CF
.....This just my opinion, I could be wrong.
Old 09-30-2010, 06:46 AM
I believe skyskijason still rocks heat and settle (my method). He posts over at frybrid's forum, so check in with him. Super helpful guy.
