| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
fuel level sender
I just scored a 100 gallon auxiliary fuel tank to tote around extra veg. It has no fuel level sender or gauge. I don't want to go to the trouble to add another gauge in the cab.
Is anyone familiar with a mechanical or electrical fuel level sender gauge that I could mount in / to the tank? Thanks! EDIT: While the fuel level would be nice to know, my main interest is making sure I don't overfill the tank when going from dumpster to tank. Anyone have experience with those whistle type fill alarms? Would it work with something as thick as SVO? Other ideas? Thanks! Last edited by CharlieC; 09-22-2010 at 04:08 PM. |
What size inlet is on the tank? and have you seen the gas caps that have a cork on a spiral rod? as the cork floats the rod twists and the needle in the cap revolves. I bet you could get one off a riding mower.
But for the whistler you mentioned, I've got NO experience, and have never heard of such a thing. I'm going to have to google it. |
ive used a stick for the last 7 years in my old IH. its never been wrong.
now thats funny ![]() If it ain't broke don't fix it, right? |
make sure it calibrated properly ralph, and measure you efficiency by hours or miles and using the notches in the stick. not the lie-ometer.
I don't know what material your tank is made of , but I had a similar problem on an aluminum tank . It was a fairly thick gauge so I drilled and tapped a 1/8" NPT hole in the top and bottom of one side of the tank and installed 90 degree hose barb fittings with clear tubing between them for a sight gauge. If you are concerned with potential leaks you could install a valve at the bottom fitting and close it when you don't need it . You can tell at a glance what the level is in the tank . I have used it for about three years with no problem .
