Can I use this oil? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 7 Old 09-17-2010, 05:16 PM Thread Starter
simone0414's Avatar
Can I use this oil?
Can I use this oil? - Forums
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #2 of 7 Old 09-19-2010, 05:41 PM
What kind of CF system do you have?
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #3 of 7 Old 09-22-2010, 09:07 PM Thread Starter
simone0414's Avatar
I have a modified ACME Juicerator. I heat my oil to 140 & gravity feed through the juicer. Works very well.
post #4 of 7 Old 09-24-2010, 12:44 PM
Aaron Berk's Avatar
I read all the Frybrid posts, and it looks like you didn't get a solid answer.
Here's one for you, FORGET IT
It sounds like you have an option to hook up with their future oil, but forget the drums. And if your a nice guy and they need it gone, haul it off to some one elses dumpster.
I personally wouldn't even consider nasty oil like that, but then again I may just be spoiled.
Oh, and put your location in your profile.
97 F250 ext cab lwb 4x2
AirDog2 and FASS HD (it's a WVO RR setup)
Simple Centrifuge filtering method
203 degree Mod, DIY homegrown intake, CCV mod, battery relocation,
215amp Ambulance Alt.
EBPV gut, Pedestal gut & cut
Diamond Eye 4" (3" dp) turbo back straight pipe
no kitty, no muffler
Aaron Berk is offline
post #5 of 7 Old 09-24-2010, 12:59 PM
rolsmojave3's Avatar
Skip the nasty oil and see what it's like in the future. Was it frozen chicken?
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #6 of 7 Old 09-26-2010, 01:22 PM Thread Starter
simone0414's Avatar
I'm not sure if the chicken is frozen or not but my guess would be yes. Does that make a difference?
post #7 of 7 Old 09-26-2010, 02:46 PM
No. Unless the product was manufacturered as a breaded pruduct it was not likely prepared from frozen.
I would say skip the source all together. For sure skip the oil that is there. I would not get too excited about the oil improving either.
Can a chicken joint provide a quality WVO? Absolutely. I source from a KFC at the moment and with the correct procedure and equipment, almost anything is possible.
99 F350 7.3
B100 by Biopro 190
