| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
OBS Electric Fuel Conversion and WVO
I've got a 1997 OBS and a new Vegistroke system on order, but with the recent owner switch the OBS Vegistroke kit is no longer available. So, I'm covered on the veggie side, but I'm trying to figure out the electric fuel pump conversion on the diesel side. I think I understand that I need to create a deadhead type system for the diesel side. It seems most people recommend getting rid of the stock fuel bowl (although that doesn't seem to be what DFA did in their kit according to the installation instructions).
I'd like to make this an inexpensive conversion while still maintaining reliability. Easy to find replacement parts (filters, pumps, etc) is also a huge plus. I should also mention that I'm not concerned with power upgrades. My main question is do I need to use a regulated pump (FASS or Raptor) or can I use a less expensive pump (like the 99+ Superduty) with an inline regulator? If so, which regulator would work? I notice when most people (without a wvo system) do this conversion, they do a regulated return with something like an Aeromotive regulator. However, I need to do my pressure regulation on the feed side because I'm going to be using my return ports on the block for WVO with the Vegistroke. Would an Aeromotive still work? Basically I'm looking at doing it like this guy (scroll halfway down), but without the regulated return. I've researched quite a bit, but I'm still confused so your help is much appreciated! |
![]() the easist thing to do would be an internally regulated pump like the FASS or Raptor. in fact that is what i would reccomend if your using the return ports for vo. install the pump and be done. you can use an SD pump and Aeromotive regualtor but that adds complexity and parts. i will be deleting my fuel bowl (optional), and using two regualted pumps, vo and d2. |
I did an electric fuel system conversion on my d2 side to create two dead head fuel systems (d2 and svo). I did go ahead and use an internally regulated pump. I'm not sure if inline regulators work well on the feed side or if they need to be on the return.
Here is a link to what I did. I later added a purge valve on the SVO side. Electric fuel system upgrade on veg conversion. My electric fuel system conversion, including fuel bowl delete (good move), was based on this writeup. Easy to follow instructions, easy to get parts. Two thumbs up on this one. It used the stock banjo bolt and fuel lines, which greatly eases the installation. 97-Stroker - Electric Fuel Install |
Thanks for the welcome! Curious, what will you be using for your water separator and filter? I see what you mean about the FASS or Raptor being simpler, but it seems it would be about half the price to do a SD pump and pressure regulator. |
Thanks for the super helpful links! It looks like you just used the Napa 4770 base and filter before the Raptor and nothing post pump. In my link above for "Tim's" electric fuel conversion, he uses a Racor water separator before the pump and a Napa 4770 base with filter after the pump. Do you think the Racor is necessary? |
On the d2 side, I did not use any filter prepump, and I used the NAPA 4770 post pump. I give up water separation by doing that, but I decided that it wasn't that big of a deal since I use so little diesel. If you wanted both, you could buy two bases, put a water separator prepump and then the filter post pump. On the SVO side, I use a Racor 1000 prepump. That filter needs to be on the suction side (both because of pressure and to maintain the water block feature). Keep the questions coming, I'm happy to help. |
Sorry if these are remedial questions, I'm a fuel system newb. |
Water separation only works on the vacuum side, while fine filtration works best on the pressure side, hence two separate filters. Pick your poison on what you use. I would suggest something bomber like the Racor 1000 for the WVO side. On the D2 side, the napa bases / filters will work just fine. |
As far as my WVO side, shouldn't I be covered for water separation with the Vegistroke system? |
I have a bit of a different setup because I have my rig setup to filter on-board. That's controversial around here and different than what a lot of guys do. |
