Poly pipe for WVO??? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 08-25-2010, 03:35 AM
Hillbilly Deluxe
Feedback Score: 3 reviews
Okay guys here's one for you...
I am a Well Water Service Tech. I have access to tons of black poly water pipe from 3/4" to 1 1/4". Plus all sorts of barbed poly fittings and clamps. I also have a bunch of 1/2hp jet pumps that i am planning on using as filter pumps and transfer pumps on my set up.
My question is this.... Has anyone ever tried using poly pipe before? I have heard that PVC will degrade over time, will the same happen to poly??
Thanks.
Old 08-25-2010, 03:36 AM
Hillbilly Deluxe
Also what about PEX tubing?? I have access to a ton of that as well
Old 08-25-2010, 05:04 AM
i used pex to rough things in, and where ever i used heat, it leaked. black iron with gas dope seems to be leak free for along time.
Old 08-25-2010, 08:11 AM
are you asking about the material for conversion, filtering, storage, etc?
Old 08-25-2010, 01:01 PM
If PVC pipe degrades I am in trouble. Fact is that I have PVC all over in my VO operations and never had a problem......that was a bout five years ago I built it all.
IMHO, PVC drgredation is kind of like copper tubing in an aluminum fuel tank. Many claim catastrophic failures but cant provide proof.
Old 08-25-2010, 02:19 PM
Hillbilly Deluxe
No no... strictly for the filtering, processing, and storage of the WVO. Pex is good to 180F, i have access to tons of that too. I would think it would be okay, unless it would stand up to the WVO for some reason.
Old 08-26-2010, 05:06 AM
should be fine. just keep an eye on your wvo temps if the hot portions are pvc. Clay had a near meltdown.
Old 08-29-2010, 10:40 PM
Im using pex. But its only got 2 months of use. No problems yet using oil at 180 deg.
Old 08-29-2010, 10:42 PM
BOSS LEVEL
isnt clay running pvc atm in his garage?
Old 09-10-2010, 12:05 PM
I use a piece of pvc pipe for a stir stick so I just left it in my barrel. Once I heated the oil to 175 I pulled it out and it was no longer straight
As soon as I get done with moving and get situated my new system will be all steel pipe
