50/50 waste oil/trans fluid and diesel fuel mix - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 33 Old 08-17-2010, 03:57 PM Thread Starter
crazyasswhiteboy's Avatar
does it work? how could i filter the oil/trans fluid? and everywhere im reading says i can dump the 50/50 mix right in my tank no heater or anything is necessary
'02 CCSB 7.3
Edge Evolution
Big Head Wastegate
AEM CAI
4" turbo back exhaust straight into 5" stack. prolly back to 4" rear exit soon
Gauges
Gillet Diesel fuel return spring.
Considering sale or trade. pm if interested.
crazyasswhiteboy is offline
post #2 of 33 Old 08-17-2010, 04:31 PM
I have used this 50/50 mix for almost 3 years,nearing 100k miles between 3 trucks that I presently own and I have had NO issues from this fuel mix. All 3 are 7.3 trucks
It simplyfies the process if you can get clean used oil-No sludge or entrained water. If it is WMO that is brown,not black then leave it alone as this is very hard to clean enough to feel safe to use IMO.
I use a centrifuge to clean the WMO that I use,this is a hard system to beat once past initial start up cost. I have run this mix across the winter in TENN with no issues although my truck is parked overnight in a heated basement garage.
It is almost a given that anyone who says it is a bad idea to use WMO has no actual experience using it.
cantrellc123 is offline
post #3 of 33 Old 08-17-2010, 04:41 PM
no-tel-in's Avatar
I have run up to 12 gallons of waste oil at a time, just make sure it is clean
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #4 of 33 Old 08-17-2010, 05:52 PM Thread Starter
how hard is it to build a centrifuge setup and what does it cost? and how much space does it take up
'02 CCSB 7.3
Edge Evolution
Big Head Wastegate
AEM CAI
Gauges
post #5 of 33 Old 08-18-2010, 04:44 AM
Space wise a 10 x 10 area would be enough I believe.
I have a Simple Centrifuge brand of centrifuge (CF). Google that and other brands to learn more about these products. I have at least 1500.00 in all that I have if not some more. Of course I am going thru about 50 gallons of WMO per week at a 50/50 ratio so there was a quick return on that money for me.
I use my tractor front end loader to raise a drum of WMO high enough for gravity flow into the CF. Others use regulated air pressure to force the oil into the CF
post #6 of 33 Old 08-18-2010, 09:31 AM Thread Starter
alright ill have to loook into that. thanks.
'02 CCSB 7.3
Edge Evolution
Big Head Wastegate
AEM CAI
Gauges
post #7 of 33 Old 08-22-2010, 08:17 PM
Aaron Berk's Avatar
Not to be weird or any thing, but how do you get 50/50 mix out of 3 products?
Or are you asking "50/50 mix = WMO+diesel" and then option 2 "50/50 mix = W ATF+Diesel"
My first impression was that your asking about mixing ALL 3, but that's not the case right?
97 F250 ext cab lwb 4x2
AirDog2 and FASS HD (it's a WVO RR setup)
Simple Centrifuge filtering method
203 degree Mod, DIY homegrown intake, CCV mod, battery relocation,
215amp Ambulance Alt.
EBPV gut, Pedestal gut & cut
Diamond Eye 4" (3" dp) turbo back straight pipe
no kitty, no muffler
Aaron Berk is offline
post #8 of 33 Old 08-23-2010, 04:17 PM
Generally I consider used motor oil and used ATF under the heading of WMO. While this is not entirely correct,most of the "WMO" that I recieve is a mixture of both. Your option #1 and #2 are both correct.
post #9 of 33 Old 09-05-2010, 06:29 AM
i dont use waist motor oil but i run about 80-85% used filterd ATF, i filter it 5 times through 5 micron filters. truck runs great about 3 mpg better on hwy. little hard to start on the cold mornings, i just let the glow plugs do their thing for a min or 2 and she fires right up. i tried 100% atf and the only thing i noticed was that the eng ran rough at idle, not like a miss but like it had a big cam in it, so i cut the mix back a little, add plenty of ctane booster and drive it like i stole it. btw i would not try this in anything but a 7.3L.
BlackSmoke03 is offline
post #10 of 33 Old 09-05-2010, 06:34 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
WMO & ATF better filter the crap out of that stuff. It raises hell on injectors.
Not to mention a good way to cause cancer
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
