Simple cetrifure setup - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 06-27-2010, 09:04 AM
Ok my Simple Centrifuge is due to arive Monday.
I will be using a HWH to heat the oil before the fuge.
What are the best materials to use for all the connections.
Would pex suffice as the piping?
More Q's to come.
Would using soldered ball valves be ok?
Old 06-27-2010, 11:55 AM
I use black iron, and brass valves on my heated side. And clear 3/4 ID flexible tubing for every thing else.
I'm liking the idea of plastic tubing for EVERYTHING more and more though. I might be switching out my black iron and in line heater for a different set up soon.
You can follow the link in my sig to see how things run right now if your interested.
PEX sounds ok to me, any one else?
Old 06-27-2010, 04:51 PM
I used PVC and Vinyl- no issues thus far- I ithink ts a little over 4 years now.
Old 06-28-2010, 05:04 AM
PVC should be fine, just pay attention to the heat limits and stay well within them.
Old 06-28-2010, 08:05 AM
I don't know nuttin....
I used PVC on my first attemp to build the CF setup, the heat made all the joints come loose, just like it melted the glue. It wasn't even that hot....140* So i changed all the PVC out and used black iron - i'm talking about all the hot side...i still have pvc on it where no heat is present or minimal.
Old 06-28-2010, 08:30 AM
I was hoping to stay away from black pipe.
I like to cut things a little long and then trim them down to size. Can't do that with black pipe. Have to have exact measure's and have the thread put on at HD.
I have some 1" ball valves that I got real cheap but they are soldered connections. Copper is 100% no good with wvo right?
Old 06-28-2010, 08:51 AM
Oh to hyjack my own tread. I got an email from the guy I bought my truck from in Marlyand and when my wife and I stopped in DC to check out the Smithsonians I got a speeding ticket form a mobile speed camera. I still had the guys plates on.
$200 for 21 over... It was a Freeway with a 40 mph speed limit!!!!!! WTF
I was thinking i was doing 60 and thought the speed limit was 65.
The only good thing is the guy wont get any points on his license. DC speed cameras dont incur points.
Old 06-28-2010, 10:20 AM
right
