under bed oem replacement tank? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 06-24-2010, 05:21 PM
Question under bed oem replacement tank?
Any one have a lead on non steel under bed tanks? I'd like to ditch my stock front tank for something wvo friendly. I've seen custom under bed tanks in the 40 gal range, but have yet to find a cost effective non steel tank.
Any thoughts?
Old 06-25-2010, 06:20 AM
I don't know nuttin....
I have heard (don't know this as fact) that these factory tanks have a liner inside preventing rust and such. Not sure of that but if its true, it should be WVO compatible. Also there are some years that had plastic diesel tanks.
Old 06-25-2010, 09:05 AM
Thanks Clay
I think I found one.
No-Rust Polyethylene Gas Tanks - JCWhitney
I'm going to get on the horn with them and make sure, before I buy
Old 06-25-2010, 09:22 AM
Don't put bio diesel in that tank though... Big no no!
Old 06-25-2010, 09:40 AM
Ok, no bio
I'm only planning on ever running WVO, so I should be ok with it then.
But um.. whats the deal with Bio-d will it eat the tank apart?
Old 06-25-2010, 09:46 AM
Won't eat the tank but will remove the urathane coating in pieses which causes all sorts of hell.
Old 06-25-2010, 10:09 AM
I've been running svo in the front stock tank for 40K miles. With just a hot fox in there you're never going to generate enough heat to have a significant worry with poly. Save your money for something more interesting than an 18 gallon fuel tank.
Old 06-25-2010, 10:12 AM
LOL, you go right ahead and run it that way but please don't be giving advice like that.
Its possible you have the factory coated tank. But others who read this may not have and you WILL get poly in there eventually. It doesn't take much heat at all.
Old 06-28-2010, 04:40 AM
im almost positive i have major poly issue in my front tank.
Old 06-28-2010, 06:13 AM
What do you notice that makes you think that?
