Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 05-08-2007, 07:58 AM
SoTX SoTX is offline
Cetane Booster and Performance Improver
Motorcraft/Ford sells the stuff. Is this truely necessary or is this a gimick. I drive an 07 6.0. Asked my dealer about it and they said no, but also said they had never heard of this Ford additive. I did a search on here for Cetane but no real answers either way. Anybody got the skinny on if this chit is needed. Is there any literature on it from Ford?
Thanks
Old 05-08-2007, 08:00 AM
Dave Dave is online now
Obama sucks
Its a good thing especially with the new ULSD fuel it gets the mileage almost back up to normal
Old 05-08-2007, 08:42 AM
F-350MAN F-350MAN is offline
they do have it I buy it every now & then from a dealer close by but normally I use Diesel Kleen, Plus I dont think you really need addative in an 07 but I could be wrong
Old 05-08-2007, 08:50 AM
Well F-350man that's where I am on the fence. The stuff says for 2007 and earlier but definetly not for the 2008's. I am trying to find out a definetive answer and so far from all I have talked to and all I have read it is kinda one of those situations where everyone says it can't hurt so do it. But if my 07 does not require it then why spend the money. I am still researching. Thanks
Old 05-08-2007, 08:56 AM
Obama sucks
None of them specifically require it. but its a great thing with the lack of lubrication in the new fuel
Old 05-08-2007, 09:11 AM
Sciulli Sciulli is offline
Send a message via AIM to Sciulli
If your worried about lubrication 3% bio-Diesel to your take will take care of all of your problems, not to mention that 1 gallon of b100 is roughly 3.50-4.00bucks and that will last you just as long as one of those lubrication bottles.
*comes directly to me from a FSE from Ford, and since your under 5% no warranty issues*
Old 05-08-2007, 01:36 PM
3ddiver 3ddiver is offline
I have a bottle in front of me and it says "This diesel fuel additive does not comply with federal ultra-low sulfer content requirements for use in model year 2007 and newer diesel motor vehicles or model year 2011 and newer diesel non-off road equipment engines. This is my first bottle of this and I have been using the diesel cleen up until now. I think I read on here that it is the same as Stanadyne and it seems to be highly recommended. I do not think that you should use this in your truck from what it sounds like on the bottle.
Old 05-08-2007, 01:40 PM
Obama sucks
FYI That would actually apply to the 08 fords the 6.4 is the only one so far that is required to run ULSD
Old 05-08-2007, 03:04 PM
reddog848 reddog848 is offline
I have used Lucas products in all my diesels (18 wheelers) and in my 97 7.3. It gets me about 1 or 2 mor mpg's and give the lubrication you need. It will definatly add a few ground HP's.
I'm new here so I just thought I'd put my pennies worth in.
Reddog 848
Old 05-11-2007, 12:08 PM
tracymangus tracymangus is offline
Cetane number is like the octane rating of Gas. Diesel needs to be around 45-48 for max performance. The ULSD in colorado averages about 35 cetane. All the dealers here recommend it for improved fuel mileage for 06 and prior. I noticed that the new bottles have a ULSD label on them as well.
