Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
  #31 (permalink)
Old 09-27-2007, 06:04 PM
Dave Dave is offline
Broken shoulder mod
Originally Posted by billbigrig View Post
or you can use atf in it to i use it in the big rig not a lot
I wouldnt be using ATF its actually hard on components and it makes your fuel red like off road fuel. You dont wanna have red fuel big fines!!
  #32 (permalink)
Old 09-28-2007, 05:55 AM
billbigrig billbigrig is offline
not that much in are to turn red
  #33 (permalink)
Old 09-28-2007, 02:02 PM
towdad towdad is offline
i run it in my 06 work truck and my 07 personal truck. i notice both power and mileage increases. for the 6.4 you have to use the one that is made for the 6.4.i have 100,000 on my 06 and i love this stuff. (the one that ford sells that says powerstroke cetene boost and poformance improver)good stuff!
  #34 (permalink)
Old 05-09-2008, 02:20 PM
samiam samiam is offline
Living on a prayer
I'll throw a vote for the motorcraft cetane boost and performance improver. i have quicker acceleration, the engine is much more quiet, no more white smoke at startup, and no loss of fuel efficiency.
  #35 (permalink)
Old 05-10-2008, 10:03 AM
Sciulli Sciulli is offline
Send a message via AIM to Sciulli
If you need cetane boost you might as well buy a regaurl diesel fuel conditoner. IT will help it many more ways then just C-tane.
  #36 (permalink)
Old 05-14-2008, 04:49 PM
alberta_stroker alberta_stroker is offline
further to reddog848's comments, I have used Lucas and recently tried Howe's additives.
The key is adding lubricity to ULED. Without the sulfur, the lubricity of new diesel is alot lower than in the past. These additives help fix that. I believe both lucas and Howe's fix that issue.
I have run both in my truck, and find the Howe's had the biggest impact, "seat of the pants" if you will.
  #37 (permalink)
Old 05-14-2008, 08:59 PM
vwsrock vwsrock is offline
BUY IT!!! USE IT!!! EVEN THOUGH YOU ARE PAYING MORE, YOU ARE NOT GETTING ANYWHERE WHAT YOU NEED AS FAR AS LUBRICITY!!!
  #38 (permalink)
Old 05-14-2008, 09:33 PM
thomas5853 thomas5853 is offline
Send a message via AIM to thomas5853
Cetane Booster harmful?
I just got my first diesel, it is a 2003 Ford F250 6.0L 4Dr Crew Cab 2wd with 20100 miles. I have added an airaid replacement filter, diablo tuner, and removed the muffler for better sound. Future project is a 4" or 5" turbo back exhaust. I have done a few trips and I get about 15 to 20 mpg in the city. The other day I took a trip to the mountains and was doing 80 and then 75. I still got 20 mpg on the economy setting. Since I have added Power Service Diesel Kleen + Cetane Boost, I have noticed lower performance and I have been producing black smoke (unburned fuel?). I am currently waiting to empty the tank and then refill it to see if it was the booster, or if there is something else wrong. Anyone have any ideas?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
