Will this pump work? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 05-02-2010, 06:15 AM
Hey all,
I need a pump to get the oil from my clean barrel to my truck or storage. I saw this on ebay and wondered if it will work. Or if you have a better suggestion, please let me know.
Tuthill Three Phase AC Lubrication Pump 1/2HP 0.5GPM NR - eBay (item 370361859096 end time May-07-10 12:40:34 PDT)
Thanks,
David
Old 05-02-2010, 11:31 AM
You got 3 phase power? Usually only commercial buildings have 3 phase.
Old 05-02-2010, 11:36 AM
shaking things up
if you have 3 phase then yes
Old 05-02-2010, 12:45 PM
Thanks for the replies. Nope, I don't have 3 phase power. What about this?
Tuthill Cast Iron Diesel Fuel Transfer Pump 115V FR1620 - eBay (item 140397553904 end time May-06-10 20:48:27 PDT)
Old 05-02-2010, 01:10 PM
shaking things up
that would work
Old 05-02-2010, 05:59 PM
That is what I use for fueling.
Anyone using Leons monster pump? I think that may be the next VO purchase for me. I'm thinking under 15 minutes to transfer a tote would be nice....
Old 05-04-2010, 06:38 AM
tubular031 does i believe
Old 05-10-2010, 10:44 AM
That is what I use now. When I moved my totes to my moms new place, I moved 300 ish gal at 35 ish degrees and about 15 minutes later it was done! I sure like this thing!
Monster Pump
I run mine off my 3500 watt champ gen when I get oil from my totes since there is no power around. My 1500 watt inverter will not kick start the pump. My gen runs the pump and a 250 watt light all the time like its nothing.
Old 05-10-2010, 11:04 AM
This is the one I use except I added a screen filter to it. I use it for waste ATF and it will empty a 55 gal barrel in about 10 minutes. I have 25' suction and 15' outlet hose
New Waste Oil Transfer Pump,Biodiesel,WVO,SVO,Hydraulic - eBay (item 130389039731 end time May-12-10 19:04:56 PDT)
Old 05-10-2010, 11:08 AM
Monster Pump
What's a cam lock connector?
After seeing that vid I wish I would've bought that pump
