Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > Big Rigs
Big Rigs Over the road truckin' talk
View Poll Results: Which Trans Type: Straight Job or Hi/Low
Straight 3 9.68%
Hi/Low 28 90.32%
Voters: 31. You may not vote on this poll
  #21 (permalink)
Old 05-25-2009, 05:14 PM
2005F250 2005F250 is offline
Originally Posted by symbols View Post
Ok, I've asked this question a thousand times and nobody has ever been able to tell me the answer but apparently I've been asking the wrong folks. What is double clutching?
Look it up on youtube.
  #22 (permalink)
Old 05-25-2009, 05:46 PM
RadarRider RadarRider is offline
Central Scrutinizer
It's "technically" the way manufacturers like Road Ranger want you to shift. Basically; you're in a gear, build up to a certain RPM, depress the clutch, shift into neutral, depress the clutch, & shift into the next gear.
  #23 (permalink)
Old 05-25-2009, 05:48 PM
dercody dercody is offline
Desert Storm Vet
Send a message via Yahoo to dercody
hi/low is much better, and then float the gears is much easier and smoother.
  #24 (permalink)
Old 05-25-2009, 05:50 PM
Central Scrutinizer
Ok. Who were the 2 people that chose the straight job!?!?!?
  #25 (permalink)
Old 05-25-2009, 06:10 PM
READNECK READNECK is offline
Originally Posted by RadarRider View Post
I agree powershifting being easier, & saves on the clutch...........but try powershifting with a REAL heavy load & see what it does.
what do you think will happen? I have hauled a grove crane that wieghs about 70,000lbs, 100,000lbs including the truck and a D8 cat with a 14 foot wide blade and rippers that wieghs about 85,000lbs, 115,000lbs including the truck and i used the clutch to get moving and then never touch it again till i stop. it just take's some practice and a few miles under your belt. as far as whitch transmission i prefer. i like a 18 speed, most of the time i drive it like it is a 8 speed but it is nice to be able to split the gears when you need too.
  #26 (permalink)
Old 05-26-2009, 08:45 AM
symbols symbols is offline
Nonsense specialist
Thanks
Looks pointless and ricerish for a daily street driver
  #27 (permalink)
Old 05-26-2009, 08:53 AM
wriott wriott is offline
BUILT & BROKE BY ME
Thanks
double clutching is only needed on "unsyncroed" (sp?) trans
  #28 (permalink)
Old 05-26-2009, 08:57 AM
BUILT & BROKE BY ME
Here's a question I'm too afraid to ask my instructor because it sounds stupid, but here goes; Say you had a 9spd. You know how you can drop 2 or 3 gears when slowing down, right? Like if you were doing 55mph in 9th & you slow down to 30, you can drop to 6th. Is it possible, say if you were doing 55 in 9th & dropped down to 25mph, can you drop your splitter, shift into neutral, & throw it into 5th?
it depends on the gear ratios in the trans/rear end, in my autocars i can go from 9th to 5th if i lug the motor to about 500 RPM in 9th and then rev it to about 2800 RPM and i can go into 5th. on my freightliner i can only downshift 3 gear as the ratios a farther apart (OTR truck) compared to my autocars where i can drop 4 gears because the ratios are closer (onsite truck)
  #29 (permalink)
Old 05-26-2009, 09:30 AM
phil287 phil287 is offline
here at work we have a few trucks that are straight, a few that are auto and a few 10 speeds. i like the 10's the best out of all of them. the autos are just plain boring. i think anything thats stick keeps you more alert when you are driving.but i prefer a splitter.
Phil
  #30 (permalink)
Old 06-04-2009, 02:05 AM
6point0damn2004 6point0damn2004 is offline
<---- BAD @$$ !!!
those twin stick trucks are boggles my mind, I give them props!
