Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > Big Rigs
Big Rigs Over the road truckin' talk
Old 05-05-2008, 09:09 PM
twhouse twhouse is offline
100000 hp
May be the wrong thread but - - if this link works it is an example of what our powerstrokers could grow up to be.
Emma Maersk, A Look Under The Hood - World's Largest Ship and Engine | gCaptain.com
oops, copied the wrong link last time.
Old 05-05-2008, 09:15 PM
07_Fx4 07_Fx4 is offline
Send a message via MSN to 07_Fx4
i've seen that before .... that's some wild **** .... it had to take forever to build that!
Old 05-05-2008, 10:17 PM
how many
how many powerstrokers can you fit in one hole?
Agree with the NRA sticker, will be one on Clifford as soon as we
get him organized.
Old 05-06-2008, 03:01 AM
rednekexprez rednekexprez is offline
"Bear"
I figured the injectors were just a 2" tube dumping fuel....lol...
Old 05-14-2008, 11:02 AM
strokerguy strokerguy is offline
i wonder what the mpg are on that
Old 05-14-2008, 11:19 AM
Doakster Doakster is offline
Well the injectors on this engine probably are a little more than two inches in diameter. For example a 6000hp motor I used to work on had 2 inch diameter injector tubes.
I used to be an engineer on commercial ships and worked on motors similar to this, not as big, but similar.
Engines in this size can have up to 4 injectors per cylinder, one just can't inject enough fuel and cover the entire area of the combustion chamber. Also each cylinder will have it's own fuel pump, a fuel pump the size of a small car.
Surprisingly these engines are very simple in concept and operation, they are just huge rotating masses. They are much simpler as far as electronics and controls than our lovely powerstrokes.
Also engines in this size(low speed diesel) can often be completely reversed by the used of compressed air injected into the combustion chamber, the air stop the engine and forces it to rotate in the opposite direction, and also the air is used to start the engine as well.
Old 05-14-2008, 11:34 AM
stroker27 stroker27 is offline
dang that thing is huge!!!
Old 05-14-2008, 11:50 AM
redstroker_2002 redstroker_2002 is offline
KVFD
damn that is amazing!
