Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Off-Topic > Big Rigs
Big Rigs Over the road truckin' talk
Old 02-19-2008, 01:25 AM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
8V92 SS Power tricks 63B/S help
So I am over here in Iraq as a lot of you know. I just took delivery of a brand new HEMTT Wrecker. I am trying to get more power out of it. I have done a couple lil tricks to it and got some decent Coal out of the exhaust but I want mor torqe. I also have an older pre computer Detroit 8V92 SS that I know there are a ton of power building tricks out there for. I just dont know them. Any help would be cool.
Old 02-19-2008, 03:41 AM
rednekexprez rednekexprez is offline
"Bear"
I cant help with the mods just wanted to say thanx!!!!!!I dont think yall get told that enough...I was over there 18 months and I know....keep up the good work....
Old 02-20-2008, 01:25 AM
Heavy Equipment 911
Thanks man, been wanting to tell you for a long time that I think both of your trucks are sweet. The reg cab is look I am trying to go for on mine!
Old 02-20-2008, 01:31 PM
Colotow Colotow is offline
Location: Quit Iraq, got a house in Tooele, Ut, and finishing remodeling the old one in Colorado
ummm, dim memorys!!
is it a mechanical or electronic?
i think if it's mechanical, there is a throttle delay. pop the valve covers, look for a 5th rack arm, going into a resivour. it's got an orifice in it, bleeds out the oil, so the throttle can't snap to wide open, cut's down the smoke. take out the orifice, all done!
if you got someone who is really, really good, rack and valve adjustments ("overhead") will make a big difference, they are normally right on new, but it is a periodic adjustment item. but, if no one is experienced, you can loose as much or more as you MIGHT gain by not getting it right.
also, if you're on good terms with your welder, cut the end off the muffler and gut it, then weld the end back on. you'll hear a little more turbo under power, but wait til you get into the jakes!!! WHOO HOO, knock the coconuts off the trees!!.
if you aren't experienced, do not mess around inside the govenor housing box!!! the throttle goes to full fuel when not running, go screwing around in there and you can get a nasty runaway when you fire it. seen that happen a few times, it ain't never pretty. same for trying to pinch off the return line, it can force too much fuel into the injectors.
remember, springs give fuel, flyweights take it away in a mechanical governor.
and, blow out or replace the air filter often. make sure no exhaust leaks, they cost boost.
if it's a DDEC, you'll need a prolink to uprate it. hets are 505 hp, but not sure if the hemtt will support that. been away from them for too long.
Old 02-20-2008, 01:43 PM
720Deere 720Deere is offline
There is no such thing as big torque in Detroit 2 stroke but the 92 will make some power. You should be able to get well over 400 hp out of it.
