Go Back   Ford Powerstroke Diesel Forum > PowerStroke.org Supporting Vendors > BD Diesel Performance
BD Diesel Performance BD Diesel Performance
  #21 (permalink)
Old 01-06-2009, 04:43 PM
Dallas4x4 Dallas4x4 is offline
Originally Posted by Dave At BD Power View Post
Sorry nothing available for the early 99"s
Make something for us 94-97s!!!
  #22 (permalink)
Old 01-07-2009, 09:34 AM
Dave At BD Power Dave At BD Power is offline
Originally Posted by HVAC SuperTech View Post
well then......DANG! haha
I know, it is a tough go on those early 99's, I keep telling the R&D department that there is a large demand for a conversion kit. With that said we are starting to go back and develop some products for the 7.3L's. We are getting ready to release the Extruded Tube Designed intercooler for the 7.3L and 6.0L's and yes they will work on the early 99's
I know there is not a lot being made for these trucks and that's a shame because there are nice rigs and a ton of them still on the roads! Our turbo department sells a smaller AR turbine housing for them that does a good job of increasing spool up time but those turbo use a odd wheel setup that rotates in the opposite direction?
  #23 (permalink)
Old 01-07-2009, 09:43 AM
powersmoker powersmoker is offline
say dave how much will one of those turbos run a guy
  #24 (permalink)
Old 01-07-2009, 10:23 AM
PM on the way
  #25 (permalink)
Old 01-07-2009, 10:51 AM
REDPOWERSMOKER REDPOWERSMOKER is offline
WE ARE DOOMED
Tournaments Won: 1
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
WHAT IS THESE NEW INTERCOOLERS CAN I GET A LITTLE INFO ON THEM
  #26 (permalink)
Old 01-07-2009, 11:55 AM
There are three main types of intercooler designs, here they are in order of quality from poorest to best.
1. Stuff Fin and Tube (OEM & Competition)
2. Bar and Plate (Competition)
3. Extruded Tube (BD Diesel)
Below are some pics illustrating the difference between the different designs. BD is the only intercooler manufacture using this latest technology "Extruded Tube". We cast our own end tanks for quality control, the cast end tanks are 3 times stronger than welded and will withstand 100+ PSI.
The benefits of the BD Cool-It Intercooler design are much higher quality resulting in better reliability. The extruded tube design eliminates the heat distortion which is typical of OEM and older designed coolers. With the extra power the diesels are producing these days we are seeing more and more failures/leaks caused from heat distortion.
We see less than 1 PSI of boost loss through our intercooler design, stock coolers will typically loose about 2-4 PSI of boost. Because of this you should expect to see a few more PSI of boost as well as better flow which will obviously result in cooler EGT's as well as more usable power.
The design is complete, we are just waiting for production now, estimated shipping date is mid February. As of now we have them priced at $1599.00 but this may change, possibly even lower depending on final production costs.
Hope this helps
  #27 (permalink)
Old 01-07-2009, 12:00 PM
WE ARE DOOMED
Tournaments Won: 1
ah thank you so much
  #28 (permalink)
Old 01-07-2009, 12:28 PM
Your welcome!
  #29 (permalink)
Old 02-07-2009, 01:16 AM
Ron's power stroke Ron's power stroke is offline
do you have turbos for the early 99 trucks? or do we have to buy the whole set up, as in like an H2E?
i want to know too
the only thing on my early bird is the build date lol..keep an eye on the classified adds..I found a guy with a 01 truck going to a H2E and bought his stock set up less the plenums for $650..that was with the turbo too..the plenums I bought new..I think they where 75 a set new...
Dave what is the price of the thruster?? my stocker is seeing 32 psi too fast and to much..even with the 1.00 exhaust housing and the WW..she will surge..
PM sent, but they definitely do not fit the early 99's
  #30 (permalink)
Old 02-09-2009, 08:52 AM
BD Turbo Thruster
PM on its way, but we do not offer them for the early 99's
