Go Back   Ford Powerstroke Diesel Forum > PowerStroke.org Supporting Vendors > BD Diesel Performance
BD Diesel Performance BD Diesel Performance
  #11 (permalink)
Old 01-02-2009, 10:50 AM
outlawdiesel outlawdiesel is offline
psd
we got Turbo's BD thruster kit's here at Welcome to Outlaw Diesel :: Home if you dont see what you want please call we will get it or we will get it custom built for you!
  #12 (permalink)
Old 01-02-2009, 10:51 AM
Chewbacca Chewbacca is offline
***mins Sell-out
Send a message via AIM to Chewbacca Send a message via Skype™ to Chewbacca
Originally Posted by Dave At BD Power View Post
Bump.
Faster spool up, better efficiency resulting in lower EGT's and zero surge or flutter issues! You will not be disappointed... guaranteed!
What mods are you running?
As of right now, just intake, 4" exhaust, TW tunes, and from what I've been told, "slightly larger then stock" injectors. I'm at the point right now where I want more, and I don't think this motor will give it to me. Between a turbo, a new HPOP, its coming up on the cost of a CR ISB CTD swap.
  #13 (permalink)
Old 01-02-2009, 10:55 AM
Stroker7.3 Stroker7.3 is offline
How much PSI does the BD push? My stock turbo with my chip on only makes like 19. but a stock dodge with no chip will make 35.... i want something with alittle more than 20
  #14 (permalink)
Old 01-02-2009, 10:58 AM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
Originally Posted by flyin hawaiian View Post
we got Turbo's here at Welcome to Outlaw Diesel :: Home if you dont see what you want please call we will get it or we will get it custom built for you!
seriously bud its bad taste to post a link to your website in the BD vendors section.... you do this all the time.. instead of just putting a pointless post and a link to your site next time look at what section your posting in....
very disrespectful
-Raul
  #15 (permalink)
Old 01-02-2009, 11:00 AM
Dave At BD Power Dave At BD Power is offline
Sounds like you need to run a boost fooler with your chip, the factory wastegate is set at 20-22PSI and is likely your problem. With a good chip and a boost fooler you should be able to make 25-30PSI easily.
Comparing the powerstroke to the cummins is apples to oranges... the BD Turbo Thruster has an adjustable wastegate that is set at 35PSI, if you have a enough drive pressure than 30-35PSI of efficient boost is what you should expect... with out ANY surge issues!
  #16 (permalink)
Old 01-02-2009, 04:52 PM
***mins Sell-out
How long does it last with big sticks and 35psi?
  #17 (permalink)
Old 01-06-2009, 09:32 AM
We have only been running them for about 6 months but have not had a single failure, with that said I am confident the turbo will likely last the life of the motor, 35PSI is a conservative wastegate setting for this turbo.
  #18 (permalink)
Old 01-06-2009, 09:41 AM
REDPOWERSMOKER REDPOWERSMOKER is offline
WE ARE DOOMED
Tournaments Won: 1
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
Originally Posted by HVAC SuperTech View Post
do you have turbos for the early 99 trucks? or do we have to buy the whole set up, as in like an H2E?
i want to know too
  #19 (permalink)
Old 01-06-2009, 10:03 AM
Originally Posted by REDPOWERSMOKER View Post
i want to know too
Sorry nothing available for the early 99"s
  #20 (permalink)
Old 01-06-2009, 04:32 PM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
well then......DANG! haha
