New E4OD no OD - Ford Powerstroke Diesel Forum
BD Diesel Performance BD Diesel Performance
Old 10-15-2010, 04:38 PM
New E4OD no OD
Just put in a BD trans and converter in my 7.3 idi. She shift solid and runs great. However it is only going into OD about 5% of the time oon the freeway then the OD light blinks and its off. The TPS (FILP) is perfect. Any other ideas? It seems as if its a control issue. What other sensors correspond?
Old 10-15-2010, 05:16 PM
drives a ranger
Send a message via AIM to kanuck15
bad solenoid pack
Old 10-15-2010, 08:19 PM
Originally Posted by kanuck15 View Post
bad solenoid pack
Should be brand new and dyno tested. What else can I rule out wiring wise before I jump to intervals?
Old 10-15-2010, 08:39 PM
drives a ranger
wiring, vehicle speed sensor, wiring harnes, pcm
Old 10-17-2010, 07:44 PM
The wiring seems to be fine no shorts or bad connections. Is there a voltage page I can see or a diagram of the transmission wiring? VSS seems to be working the spedo is working.
