aFe Power Announces the Release of a Transmission Pan - Ford Powerstroke Diesel Forum
Advanced Flow Engineering
post #1 of 3 Old 04-29-2013, 08:32 AM Thread Starter
Corona, Calif. aFe Power announce the release of a Transmission Pan for the 1994-03 Ford Diesel Trucks V8-7.3L (td), P/N 46-70102.
aFe Power's new deep transmission pan brings performance engineering to the protection of your truck's transmission. This transmission pan has additional capacity for 7.5 quarts over stock. Internal and external fins transfer heat from the fluid to the ambient air for maximum cooling. This transmission pan is constructed out of durable die-cast A380 aluminum with reinforced ribs and a wrinkle black powder-coating machined fins for maximum strength and styling. Transmission pan fits the E4OD/4R100 transmission.
Internal and external fins transfer heat from the fluid to the ambient air for maximum cooling. This system incorporates a large neodymium magnetic drain plug that captures loose particles for maximum transmission protection and can be tightened using a 1/2" square socket drive. A Threaded 1/8" NPT port comes ready to use for your transmission temperature sensor. Transmission pan comes complete with all necessary hardware and the O-ring bolts directly to the factory location for a hassle-free installation.
aFePower_Shaun is offline
post #2 of 3 Old 04-29-2013, 08:38 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
sweet deal! Pics of the pan?
2000-7.3L is offline
post #3 of 3 Old 04-29-2013, 09:05 AM Thread Starter
Sure here is a pic of it for anyone interested in what it looks like.
