aFe Power Releases The New Scorcher Tuner for 2011-2012 Ford Super Duty V8-6.7L - Ford Powerstroke Diesel Forum
Advanced Flow Engineering
post #1 of 1 Old 04-24-2013, 09:54 AM Thread Starter
Corona, Ca…advanced Flow engineering (aFe Power), an industry leader in performance cold air intakes, filters, intercoolers, intake manifolds and exhaust systems is pleased to announce the release of their new Scorcher Tuner for 11-12 Ford Super Duty V8-6.7L (td).
Finally a programmer for the Power Stroke that is integrated to work with aftermarket performance products. The new Scorcher from aFe Power utilizes a fully integrated tuning system that is matched to aFe Power performance intakes, exhaust and throttle body spacers. These tunes are designed to provide maximum performance over the entire RPM range. This unit produced up to157hp and 180lbs. x ft. torque. aFe has partnered with Supechips to develop the exclusive tunes to maximize all available power without sacrificing safety to the motor. This small hand-held unit contains multiple tunes per application that can be changed to match the driving condition (performance, mileage, towing, etc.). The easy to follow prompts make this product one of the easiest and fun ways to increase power and improve drivability.
Amplify Fuel Deliver - Amplify fuel delivery and injection timing for increased horsepower and torque.
Speedometer Calibration - Speedometer Calibration resets for large tire and gear changes.
Turbo Boost Control - Maximize control of turbo boost and variable vane control.
Optimized Shift Times - Optimize shift times and patterns for better placement of available power.
Clear Check Engine Lights - Read and clear check engine lights/codes.
If anyone has any question or needs any info please let me know.
aFePower_Shaun is offline
