Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 Ford Excursion Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
  #21 (permalink)
Old 06-23-2009, 11:51 AM
powerstrokin it powerstrokin it is offline
My parents get's about 21 mpg pending on conditions on the hwy and 15 to 16 in the city driving. I live in Texas wide open roads no big cities in my area.
  #22 (permalink)
Old 06-28-2009, 01:53 PM
SD26 SD26 is offline
Best I've got with my Excursion is a high 18MPG. Wanted a 19, but it didn't happen.
I hand calculate, and I checked my speedometer and odometer with GPS to make sure it's correct. Often, they are off by 5-10%. If the ruler is wrong, everything else is too.
Lie-o-meter was pretty close when I was stock. I think it read about .6 better for MPG, and after I added the DP Tuner, it read better by a few MPG. It's just part of the entertainment system.
  #23 (permalink)
Old 06-28-2009, 04:46 PM
netpro netpro is offline
good gas mileage 25 97 PS
my 97 f250 superduty 7.3l turbo diesel with superchip gets over 20 mpg easily ...i get 18 mpg pulling a 17ft 5th wheel ... something wrong with your setup my friend....
  #24 (permalink)
Old 06-28-2009, 04:51 PM
bockhold bockhold is offline
broke college kid
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
i dont get above 16.9 when i drive my normal route
  #25 (permalink)
Old 06-28-2009, 04:56 PM
Wink re: gas mileage
Hey ... you should get a evolution chip programmer and it will improve mileage and power a lot .... too....
can you do me a favor ...here is my problem.... can you check your truck starter solenoid wiring and let me know what it is ...something is wrong here ....
i need to know the proper wiring for my starter solenoid for "starters" assuming that's the problem, on my 97 f250 PS i forgot which wires go where and after replacing the main positive power cable that goes to the batteries and the starter and a new starter i now have no power to anything for some strange reason.... no lights, radio etc.. nada... but strangly enuf the starter turns over when you " short" the terminals ....... i checked all my fuses etc seem fine ,,, and fyi it started just fine b4 i did this fix....
pls help me asap Scott
  #26 (permalink)
Old 06-28-2009, 04:57 PM
ps ... better yet if you could take a picture of it or call me @ 780-6691548 or give me your # and i can call you .... i'm pullin my hair out wondering what happened ..... arrrrrrgh!!!
  #27 (permalink)
Old 06-28-2009, 05:01 PM
sirdarkveil sirdarkveil is offline
16 to 17, from day one with this truck, still the same, I have a heavy foot and drive 75 whenever I can, keep it below 100 (thans to that speedlimiter program) If I try to get good mileage I still get 17 so I just drive and get 16. Really thought I would get closer to 20 when I bought this truck. Last truck was a Dodge dually 2wd and got 18 to 19.... but the pre 24 valve version was gutless and this truck goes!
  #28 (permalink)
Old 06-28-2009, 05:17 PM
AaronATX AaronATX is offline
Send a message via AIM to AaronATX
i totally believe it. people don't believe my numbers, the highest i've gotten is 25.54 MPG hand-calc'd, filled at the same station to the neck, verified by a GPS on miles traveled too. I think the tires really kill your mileage. I have 265/75R16 BFG a/ts on a 2WD with an exhaust, intake and TS 6 pos. chip. on the 75 setting i average about 18-19MPG mixed driving when i'm light on it. when i turn it to the 140+ and romp on it, i can expect to go about 13MPG on that tank. but normal driving has yielded really decent numbers, considering the size of these rigs. And just to verify even further, I made the ~100 mile drive twice every weekend for the entire semester last fall, and always got between 22-25 on those trips. probably 95% highway on those. the KEY is keeping it cruised at 55-60. it feels like you're crawling but going much above that starts killing mileage. Although I did have a few drives back from College Station, slightly downhill with the wind at my back, and got about 20mpg going 75-80 most of the way.
Also remember that every truck reacts a little differently, you may have a boost leak, drivetrain loss, etc.
  #29 (permalink)
Old 06-28-2009, 09:06 PM
mankypro mankypro is offline
I've been in the 20mpg range on #2 on flat freeway driving, more like 17-18 in the mountains (which is just about everywhere here) - grocery getting I do about 15.5mpg
  #30 (permalink)
Old 06-28-2009, 09:17 PM
Hawker Hawker is offline
My 450 had 4.88's from the factory. the truck weighs just under 11,000#'s empty and i was getting 10-11mpg consistently, highway and backroad. I swapped to 4.10's and flat highway i can see 21-22, backroads, 13-14 consistent.
