- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
| Sponsored Links |
My old '94 made avg. 12mpg and it had 4:10 gearing on stock tires (4x2). My '99 on 33" tire and stock 3:73 gearing (4x4) makes mid-15mpg with no engine mods. '94 - 2700rpm=75mph... '99 - 2300rpm=75mph. Aggressive tires will pull mileage too. Was getting hi-17mpg on stock tires... dropped when I installed the 33" Nitto Mud Grapplers. Gonna go back to an all-terrain tire next (same size).
Just a thought
First of all, my truck drops mileage horribly going anything over 65 - over 65 you get 15.5 to 16 Under 65 I can easily get 18 on highway trips in hill/mountain country. What are your typical cruising EGT's? Typical Boost Numbers? You might consider looking for a boost leak as that was stealing some of my power and reducing my mileage.... also +1 on getting a DP or TW chip. I have the DP and highly recommend it! I am positive the TW is excellent too from having talked to other folks here... |
I didnt think the hypertech had the ability to change the spedo calibration. I though you could only do it with a "truspeed" or something similar ![]() TruSpeed™ Speed Sensor Recalibrator · Superlift · www.superlift.com |
As for the tuner. read my last post... As for the boost numbers read my first post. as for egt, those are up and down like a roller coaster from 0-45mph they go up to less then 800ish then down at shift, then up for the next gear some, then again and repeat... towing 7000lbs behind a 7500lbs rig on 35's and about 400-1000lbs in side = 1300deg max up our biggest longest hills here in so cali (grape vine and devore). and typ is about 10-1100 up moderate long hills. boost max = 22psi and stead and no bouncing or jumping. so dont think theres a boost leak, but I guess there could be? |
My guess would be the tires, I swapped out the factory tires for a skinner profile larger height tire for use in the winter(blizzacks) and noticed a drop in mileage 265/70/16s (stock) compared to 235/85/16s (winters). As soon as I put back the stock size when the weather broke, I was back up to 16.5-17.5 mpg city (using cooking oil bio diesel)
wow only one MPG less with about 1000lbs more?
| Sponsored Links |
