Mysterious Vibation - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 15 Old 07-03-2014, 08:17 AM Thread Starter
Question Mysterious Vibation
I have a 00 excursion 4wd and everything is tight on the front end, new shocks and steering dampener, bearings are tight and no noise, tires are new (but it did it with the last 2 sets too...one set was only on for a month before we put these on. Long story.) and balanced. There is a vibration when driving between 55 and 75 on the interstate, it might do it at other times but our roads sucks so I might not be feeling it. It feels like its coming from the passenger side front but I could be wrong. My husband has checked everything he can think of and he said when he worked at firestone they had a customer with a gas burner excursion that had the same problem but no one could find what it was. Anyone have this problem and fix it? Any idea? TIA
Tiffany
DandTPerez is offline
post #2 of 15 Old 07-03-2014, 08:28 AM
sbluke55's Avatar
Quoted: 552 Post(s)
Garage
Can you feel the vibration in the steering wheel or your seat?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 15 Old 07-03-2014, 08:32 AM Thread Starter
I feel it more in the floor than anything. I don't notice much in the steering wheel at all.
post #4 of 15 Old 07-03-2014, 09:01 AM
sbluke55's Avatar
Quoted: 552 Post(s)
Garage
Mysterious Vibation
Not feeling it in the steering wheel leads me to think it's coming from the rear. I would check your u joints and carrier bearing. Is it lifted.
01 f-250, Standard
sbluke55 is offline
post #5 of 15 Old 07-03-2014, 06:59 PM
heykw's Avatar
Rotate the tires front to rear and see if the vibration moves.
Is the excursion a 4x4?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #6 of 15 Old 07-04-2014, 06:05 AM Thread Starter
Yes its 4wd. No its not lifted. The tires have been rotated and its still there. I'll get him to check the rear end and drive shaft. Thanks.
post #7 of 15 Old 07-04-2014, 11:38 AM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
Just went through something very similar. Ended up being the u-joints on the driveshaft. I ended up replacing all the u-joints on the driveshaft and 4x4 driveshaft. Problem solved
403,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #8 of 15 Old 07-05-2014, 09:06 PM
ageekwithajeep's Avatar
Quoted: 2 Post(s)
Brothers did that, new drive shaft and no more
2001 Ford Excursion
06 LJ rubicon
ageekwithajeep is offline
post #9 of 15 Old 07-05-2014, 09:45 PM
sbluke55's Avatar
Quoted: 552 Post(s)
Garage
Mysterious Vibation
I would say a new drive shaft is an extreme. Replace the u joints and carrier bearing and you should be good. If there is still a vibration issue take it to a drive line shop and have it balanced. Only way I would replace a drive shaft is if it was damaged
01 f-250, Standard
sbluke55 is offline
post #10 of 15 Old 07-15-2014, 08:29 AM
Have you figured out what was causing the vibration?? I'm getting one at 45mph.....doesn't do it below or above.....just at 45. I feel it in the seat and floor too.
Swmpbgy1
swmpbgy1 is offline
