oo Excursion, AC, Vacuum issue? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 6 Old 06-16-2014, 03:26 PM Thread Starter
OK, so with the AC running, the air comes out defrost and feet vents, but when I stop at a light or sign, it blows out the reg main vents, then when I take off again, at about 1500 RPM's, it goes back to the defrost and feet vents. I found the vac. line and block under glove box and the hoses are attached, but a nipple has nothing connected to it, although someone said it is made that way, Anyone got any ideas?
gmmahieu is offline
post #2 of 6 Old 06-16-2014, 04:59 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
Is this a gas job?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 6 Old 06-16-2014, 11:10 PM Thread Starter
yes it has the V10 4x4
gmmahieu is offline
post #4 of 6 Old 06-17-2014, 04:33 AM
LoxDiesel's Avatar
Quoted: 331 Post(s)
You have a vacuum leak then or a hose is collapsing. Check the vacuum hoses on for the air box under the hood. Sometimes they get routed to close to the exhaust.
My wifes 00 explorer had this same problem. I was never able to figure it out, but i wasn't going to throw parts at it. Ive also heard that the vacuum accumulator will fail causing this to happen.
Good luck
@loxdce
post #5 of 6 Old 07-05-2014, 06:43 PM
heykw's Avatar
So if you idle up the excursion at a stop does the a/c come out of the defrost vents?
If so you could idle up the truck and then use some type of propane gas to look for a leak.
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #6 of 6 Old 07-05-2014, 06:48 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Brake clean works also. You spray it at all your vacuum hoses and around your intake. If it revs up you have a leak.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
