Ball Joints - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 14 Old 06-16-2014, 12:45 PM Thread Starter
Ball Joints
Greetings all.......
I have a thud when coming to a stop in either drive or reverse. I have replaced all 4 shocks, both front sway bar end links and the sway bar bushings......I have to assume it is the ball joints....2000 Excusion, 7.3l, 4wd, 109k miles.
How hard are they to replace? Anyone have a link to a step by step guide???
Thanks......
Swmpbgy1
swmpbgy1 is offline
post #2 of 14 Old 06-16-2014, 12:58 PM
Vannnce's Avatar
Quoted: 13 Post(s)
Have you jacked up the front end and check for play by grabbing the wheel at 12 and 6 and shaking?
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #3 of 14 Old 06-16-2014, 01:12 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
http://youtu.be/tiIewl4RqYQ. While your in there do your u joints also
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 14 Old 06-16-2014, 01:16 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
I recommend raybestos ball joints. Best price I found was rock auto.
01 f-250, Standard
sbluke55 is offline
post #5 of 14 Old 06-16-2014, 02:10 PM
belz's Avatar
Quoted: 68 Post(s)
I got them cheaper on Amazon.
belzfone
Belz
CPA Director
belz is offline
post #6 of 14 Old 06-16-2014, 02:35 PM Thread Starter
I haven't checked them yet, but what else could it be? The end links were so rotten that there was hardly any rubber left. Like I said, the front end pops when coming to a stop in either drive or reverse.
Found this......http://www.superdutypsd.com/ball_joint_article.php
Looks pretty straight forward.
Swmpbgy1
swmpbgy1 is offline
post #7 of 14 Old 06-16-2014, 06:30 PM Thread Starter
Are they better than Moog or comparable????
Swmpbgy1
swmpbgy1 is offline
post #8 of 14 Old 06-16-2014, 07:35 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Moogs quality has gone down in resent years. Raybestos are better quality and should last longer. Plus that's what all the dodge guys are going to. And we all know they have a hard time with ball joints.
01 f-250, Standard
sbluke55 is offline
post #9 of 14 Old 06-23-2014, 05:05 AM Thread Starter
Got all 4 ball joints installed this weekend. The drivers side were not that bad, but the passengers side, both were toast. I also had to replace the inner and outer seals on the passengers side.
I followed the instructions I posted earlier.....Very straight forward.
I used the Raybestos upper and lowers from Amazon......All I can say is WOW....Drives and handles superb!
Swmpbgy1
swmpbgy1 is offline
post #10 of 14 Old 06-23-2014, 06:04 AM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Good deal. I'd get an alignment just to make sure everything is in spec.
01 f-250, Standard
sbluke55 is offline
