A/C Clutch, blend actuator fuse #24 keeps blowin - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 4 Old 06-08-2014, 01:52 PM Thread Starter
I recently purchased a 2001 Excursion limited 2wd. A/C fuse #24 keeps blowing. it will blow as soon as the key is turned on, no matter what position the HVAC function switch is in (even off).
Disconnected the AC clutch coil (blown fuse), disconnected the blend door actuator (blown fuse), disconnected the plug on the back of the interior HVAC controls where the whi/vio wire runs in (no blown fuse). At this time, I have the plugs all reconnected with the whi/vio wire removed from the plug and taped off until I can figure more out.
Out of frustration, I put a 30 amp fuse in and it didn't blow. After 5 seconds I felt the wire in the engine where the connectors are and it was warm near the high side sensor? (tan/grn wire and red/yellow in it, closest to A/C clutch plug). would a bad sensor really blow the fuse? is it my function switch in the dash?
I'm losing my mind. I also jumped the A/C compressor and it clicked in like it is supposed to without blowing an in-line fuse so I'm pretty sure it isn't the culprit.
I really need some help.
Thanks.
Last edited by jontashley; 06-08-2014 at 02:14 PM. Reason: Forgot model name in post
jontashley is offline
The Following User Says Thank You to jontashley For This Useful Post:
ageekwithajeep (06-15-2014)
post #2 of 4 Old 06-08-2014, 08:38 PM Thread Starter
Might have found the culprit
After much searching for four days, I somehow didn't see the fact that the A/C Clutch Diode had slightly melted. I will replace it tomorrow and hopefully that will solve the problem.
The fuse doesn't blow (even with the messed up diode) when I unplug the AC Compressor Clutch and the A/C compressor pressure switch.
I'm hoping that someone can maybe help me figure out what is wrong.
Do diodes get weak and fail over time? Is something else wrong that is causing the diode to fry and in turn the fuse to fail? I really need some help on this one cause I'm baffled.
Thanks in advance.
post #3 of 4 Old 06-15-2014, 12:28 PM Thread Starter
Problem Solved
New diode installed, air blows cold and fuse doesn't blow.
post #4 of 4 Old 06-15-2014, 05:57 PM
ageekwithajeep's Avatar
Quoted: 2 Post(s)
probably created a short in the system that turned it self on all the time, good to know thanks!
2001 Ford Excursion
06 LJ rubicon
ageekwithajeep is offline
