2000 not shifting or going - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 3 Old 04-29-2014, 06:03 PM Thread Starter
wadmalawjoe's Avatar
Its been quite awhile since I've been on here and this site helped me a lot with my truck. Fast forward to now a friend has the 2000 Excursion with the 7.3, automatic, 4wd and occasionally it won't shift up from first or second or won't shift at all. It mainly happens whenever he backs up, pulls forward, backs again, like when your backing a trailer. Two transmission places have looked at and neither place can get it to replicate what it does on him... crazy.... Then gets it back it will be fine for a few days and boom it happens again. One place changed the trans fluid the other place changed the transfer case fluid.
I will see my friend tomorrow so I'm hoping y'all might have a few suggestions.
Thanks in advance!
Truck; late 99 F350 SRW, 7.3, 2wd
Glowshift pillar gauges,boost,trans,egt
Riffraff air intake kit
CCV mod
Foil delete
Intake heater delete
Python remote start/alarm
Other work horse;
Ford 3000 tractor
Name; Joe
wadmalawjoe is offline
post #2 of 3 Old 05-02-2014, 11:36 PM
heykw's Avatar
How did the fluid look when they changed it? Any metal in the pan?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 3 Old 05-03-2014, 03:05 AM Thread Starter
Thanks for asking. He ended up getting the transmission rebuilt. What the rebuilders discovered was some loose bolt up inside that should have been replaced by the last people who rebuilt it. They said this particular bolt comes with the rebuild kit. With it being loose it allowed all the forward? clutches to wear out prematurely.
CCV mod
Foil delete
Other work horse;
Ford 3000 tractor
Name; Joe
