E Brake warning light? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 9 Old 04-17-2014, 02:16 PM Thread Starter
Several times recently the brake light on the dash and warning chime have activated while sitting at a light with foot on brake pedal. Same indication as if you were traveling with the emergency brake on?? E brake rarely used and certainly not recently. 2001 4X4 Limited Excursion 7.3L
Bubbalarge
Bubbalarge is offline
post #2 of 9 Old 04-17-2014, 02:52 PM
scagle1's Avatar
I believe that's just a basic brake warning light. Fluid level , brake pads is where i'd start before worrying about the e-brake.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #3 of 9 Old 04-17-2014, 03:05 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
That's not just for the e brake. There's an issue in your brake system that is setting it off.
Or the e brake pedal is a little loose and setting off the light
Sent from AutoGuide.com App
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 9 Old 04-18-2014, 08:45 AM
Quoted: 17 Post(s)
Or the micro switch could be malfuctioning. Mine did that a month ago to so. Jacked with the switch & haven't had a problem since
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #5 of 9 Old 04-18-2014, 12:42 PM
Most likely fluid level. Check.
Shining Armor is offline
post #6 of 9 Old 04-19-2014, 05:42 AM Thread Starter
Thanks for the responses. I had topped off the fluid level after the first time it happened but did it again after. Just replaced both front hubs and axel seals and the front brakes looked fine. Will check the rears and clean MFS as it has caused funky issues with my F250 in the past.
Bubbalarge
post #7 of 9 Old 04-19-2014, 08:11 AM
ageekwithajeep's Avatar
Quoted: 2 Post(s)
Just a reminder, your power steering also uses the same fluid, so there could be something going on with it too.... Sorry to bring in another aspect
2001 Ford Excursion
06 LJ rubicon
ageekwithajeep is offline
post #8 of 9 Old 04-19-2014, 09:05 AM
Rodslinger's B1TCH
try adding a little more brake fluid to the reservoir. when you press on the brake pedal the fluid level goes down slightly so it might just be making down low enough to set off the warning light light.
and the power steering pump also runs the hydroboost so make sure that's topped up... not with power steering fluid
steve604 is offline
post #9 of 9 Old 04-21-2014, 05:27 AM
timmyboy76's Avatar
check where the pedal rest, up toward the dash. You'll see what looks like a phllipspanhead. That button is what triggers the light as well. Like member mentioned, check the switch.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
