NEW TIRE Suggestions - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 10 Old 04-13-2014, 10:43 AM Thread Starter
Question NEW TIRE Suggestions
2000 7.3 2WD Excursion needs some new tires. I wasn't happy with the last set Michelins. I'm the original owner...Live in Florida. I mostly drive local city driving and the occasional 300-500 mile trips dropping/ picking up the kids from college dorms. Any recommendations?
ZTAgator is offline
post #2 of 10 Old 04-15-2014, 04:01 AM
I run Cooper Discoverer AT3s (285/75/16) 10plys. Seem to hold up decent on/off road.
They are a semi aggressive off road tire with nice road manners.
You may want to run a nice road tire if you aren't planning on trails and mud.
Shining Armor is offline
post #3 of 10 Old 04-15-2014, 05:27 PM
ageekwithajeep's Avatar
Quoted: 2 Post(s)
I run firestone destination A/T's and love them. With that said If I was running on road only I'd go with Bridgestone Duller H/T's we put them on my mom's Denali and it rides great.
2001 Ford Excursion
06 LJ rubicon
ageekwithajeep is offline
post #4 of 10 Old 04-16-2014, 08:23 AM
Quoted: 2 Post(s)
I've run the following tires on the 00 Excursion,
265 GY Wranglers
265 Bridgestone Ravo's E load
295 BFG ATKO's
285 Michelin LTX
Order of best to worse
1. Michelin
2. BFG
3. Wranglers
4. Ravo's
My opinion were the Ravo's were absolute junk, wore out fast and never had very good traction. For the price of these tires A VERY BAD IDEA.
The F2&350 both have Michelins on them now the smaller truck LTX and the bigger truck MS2's. I would have to say the MS2's seem to have as much if not more traction than the LTX's. Again 4 wheels spinning in the back should allow more traction than just two. Also limited slip in the dually and non limited slip in the 250.
The 02 X needs tires so leaning towards the Michelins or BFG's but I can get the Destinations at cost from a friend.
dougger222 is offline
post #5 of 10 Old 04-16-2014, 08:56 AM
Harley516's Avatar
I have run Destination AT's and was very impressed with traction and durability.
Harley516 is offline
post #6 of 10 Old 04-29-2014, 10:55 AM
hulahand's Avatar
What about size? Just bought our excursion and it needs new tires. wanting to get tallest tires possible without installing a lift. shows about 18mpg avg. right now. hoping taller tires and a good chip will improve that.
hulahand is offline
post #7 of 10 Old 04-29-2014, 04:35 PM
Quoted: 2 Post(s)
im 4x4 and fit 285/75/r16 with no rubbing and have run them since before i did the leveling kit.
2001 Ford Excursion
06 LJ rubicon
The Following User Says Thank You to ageekwithajeep For This Useful Post:
hulahand (04-30-2014)
post #8 of 10 Old 05-01-2014, 07:44 PM
Gunner
GunnerB's Avatar
My excursion is 2wd, I run 285/75/16 BFGoodrich Rugged Terrain T/A. They have above average road noise and suck in the mud. Great mileage so far and wet traction is great.
If i would buy again I would go with Michelin's or BFG AT KO's.
2003 F250 7.3L CC XLT SB
AIS Intake
4.5" ICON Lift
Pre-Pump/Coolant/Transmission Filter
PHP Hydra
6.0L Cooler
ISSPRO EGT/BOOST/TRANS
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
2002 EX LIMITED 7.3L
DS Trans Cooler
Bilsteins
GunnerB is offline
The Following User Says Thank You to GunnerB For This Useful Post:
hulahand (05-02-2014)
post #9 of 10 Old 05-01-2014, 07:52 PM
sprksonu's Avatar
nitto dura grapplers by far or toyo at 2's
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #10 of 10 Old 05-02-2014, 02:53 PM
Sd96's Avatar
i got 285-75-16 falken wild peaks on my 02 X 4x4. they look and ride great
Sd96 is offline
Tags
tires
