Excursion fuel tanks - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 11 Old 04-12-2014, 05:25 PM Thread Starter
hoytjr's Avatar
Do the fuel tanks need the same fuel tank mods as the trucks do?
hoytjr is offline
post #2 of 11 Old 04-14-2014, 04:47 PM
My '00 Ex has a plastic tank. No delamination/rust issues like the trucks.
Rahn is offline
post #3 of 11 Old 04-14-2014, 07:59 PM
Twawsi's Avatar
I think the OP is referring to the Hutch and Harpoon Mods. I'm planning on doing both Mods in the next few weeks.
Twawsi is offline
post #4 of 11 Old 04-15-2014, 03:59 AM
I believe the tanks and in-tank pickup/pumps are different and do not require the same modifications as the trucks.
Shining Armor is offline
post #5 of 11 Old 04-15-2014, 01:37 PM
Ahhh, ok. Gotcha. I'll have to look those up.
Rahn is offline
post #6 of 11 Old 04-16-2014, 10:40 AM
Twawsi's Avatar
not according to ALLDATA
Twawsi is offline
post #7 of 11 Old 04-16-2014, 12:10 PM
duck fan's Avatar
The Excursion will benefit from the Hutch and Harpoon mods. It has the same pickup as the trucks as well as the issue with the vent hose extending into the tank.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #8 of 11 Old 04-16-2014, 03:05 PM Thread Starter
hoytjr's Avatar
Thanks for the info
hoytjr is offline
post #9 of 11 Old 04-18-2014, 11:49 AM
I watched a video online and the tank is clearly bigger with a different looking pickup.
I can fit 43 gallons on a fill up on a 44 gallon tank.
Trucks that aren't harpooned can only fit 29 gallons.
With harpoon can fit 33 gallons.
Math doesn't ad up and the pump in the video I watched looks like a different system. No fragile pickup to break off and no pre filters. It almost looked like the pickup was attached the bottom of the tank.
Dunno.
post #10 of 11 Old 04-18-2014, 11:52 AM
Ford Truck Enthusiasts Forums - View Single Post - EXCURSION IN TANK MOD/DROPPING FUEL TANK
Says Harpoon isn't necessary. Hutch is a possibility... moving the return line. Don't see the need if the fuel pressure is correct.
