Suspension upgrades for Excursion? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 8 Old 03-18-2014, 05:32 AM Thread Starter
What's recommended for a 4x4 excursion suspension upgrade? I read somewhere about using F350 springs? I need new shocks so I figure if I would benefit from a small lift now's the time to do it. Any recommendations for kits/shocks? Thanks
2000 Ford Excursion 7.3, AIS intake, 4" MBRP exhaust, PHP Hydra Chip, Bilsteins (5100 in front and 4600 in back) and x code front springs to be added when I can find the time to put them in.
MAArcher is offline
post #2 of 8 Old 03-18-2014, 10:15 AM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
The ONLY guy to go to for Excursion suspension upgrades is Cary at CT Performance. I wish I would have done his upgrades years ago.
403,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #3 of 8 Old 03-18-2014, 10:30 AM
97workhorse's Avatar
^^^^^^Touché
2001 Ford Excursion Limited 7.3 4x4
297K on body-126k on motor as of 12/1/14
Too many extra goodies to list....
SOLD: 2012 Ford F250 6.7 Lariat (19k)
SOLD: 1997 Ford F250 7.3 (324k)
97workhorse is offline
post #4 of 8 Old 03-18-2014, 10:41 AM Thread Starter
I was just emailing with CT Performance. Its like $2,500 in parts. That's more than I can spend. I'm not all that unhappy with the ride right now. I was just thinking a little more ground clearance and a better ride than I'm getting with my worn out shocks and load range E tires. What do you think of something like this: 99 04 Ford F250 4x4 2 8" Full Lift Kit w Bilstein 5100 Shocks | eBay
MAArcher is offline
post #5 of 8 Old 03-18-2014, 11:32 AM
Twawsi's Avatar
I'd tell Cary what you are able to spend and I'd imagine he'd work something within your budget. Bottom line is, Cary is the man. I'm certain no one would want to see you get shorted by going the flee bay route. Luck of the draw there.
Twawsi is offline
post #6 of 8 Old 03-18-2014, 03:59 PM
ageekwithajeep's Avatar
Quoted: 2 Post(s)
If your only looking to level, i did leveling shackles from amazon, They give me a little lift and get the front springs away from the bump stops. Rides so much better.
2001 Ford Excursion
06 LJ rubicon
ageekwithajeep is offline
post #7 of 8 Old 03-18-2014, 05:32 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
No matter what, talk to Cary. He knows Ex suspensions inside and out, and will openly tell you the pro's and con's of each option you want to talk about.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #8 of 8 Old 03-18-2014, 05:56 PM
c dog's Avatar
Here are the parts I bought seprate over time for my excursion that I will be doing soon. I will be doing the "B" rear spring mod that every one recommends
F250 rear leaf springs Craigslist: $75
F550 "X" code front leaf springs ebay: $175 shipped
Welded 4" rear blocks powder coated ebay: $65 shipped
3" mini spring pack for the front ebay: $120 shipped
Custom adjustable front track bar ebay: $120 shipped
(4) blistien shocks: $300+- shipped
Longer rear U-bolts: $49 shipped
That's a 4" lift for around $900-$1,000. It high enough to run 35" tires.
c dog is offline
