HELP, upper track bar broken - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 10 Old 02-27-2014, 07:38 PM Thread Starter
HELP, upper track bar bolt broken
hi guy,
To day, I was driving on unpaved road, and my upper track bar was missing.
Do you know what ford parts I need to fix???
Thanks for you helps
02 7.3 EXCURSION 4X4
LIMITED EDITION
ZF6 SWAP
MBRP 4" EXHAUST
DP TUNES
AIS AIR FILTER
BILSTEIN SPECIAL VALVING FROM CT PERFORMANCE
ENERGY SUSPENSION BUSHING
Ritch is offline
post #2 of 10 Old 02-27-2014, 09:12 PM
ageekwithajeep's Avatar
Quoted: 2 Post(s)
your upper track bar just disappeared? how does that happen?
Its all one piece unless the mounts are gone should be straight forward fix
2001 Ford Excursion
06 LJ rubicon
ageekwithajeep is offline
post #3 of 10 Old 02-28-2014, 04:01 AM
Quoted: 3 Post(s)
Take a picture or try to describe it better. Your track bar is missing or your upper track bar bracket?
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #4 of 10 Old 02-28-2014, 07:44 AM Thread Starter
sorry, just forget, its the upper bolt.
LIMITED EDITION
ZF6 SWAP
MBRP 4" EXHAUST
DP TUNES
AIS AIR FILTER
Ritch is offline
post #5 of 10 Old 02-28-2014, 09:49 AM
Quoted: 2 Post(s)
oh thats a little different, all i know about that bolt is that its a 30mm head and the nut has a hook on it so you don't have to hold it while you tighten.
How did you not hear it coming loose?
2001 Ford Excursion
06 LJ rubicon
post #6 of 10 Old 02-28-2014, 01:27 PM
Quoted: 3 Post(s)
W706345-S439 -M20 Shoulder Bolt
N811886-S436 -M20x2.5 Flange Nut
01 Ex 7.3l Limited
06 headlights
post #7 of 10 Old 03-01-2014, 09:31 AM Thread Starter
THANKS,
I saw yesterday, for the upper bolt, ford used 2 different kind. A small (15mm) and a big (I think 20mm)
I'm plan to do the swap with the big bolt, just need to find a bracket from the F250 or F350 or a aftermarket.
LIMITED EDITION
ZF6 SWAP
MBRP 4" EXHAUST
DP TUNES
AIS AIR FILTER
Ritch is offline
post #8 of 10 Old 03-01-2014, 09:34 AM Thread Starter
who had picture of the adjustable system for the upper bolt of the track bar?
LIMITED EDITION
ZF6 SWAP
MBRP 4" EXHAUST
DP TUNES
AIS AIR FILTER
Ritch is offline
post #9 of 10 Old 03-02-2014, 06:23 AM
Quoted: 2 Post(s)
Originally Posted by Ritch View Post
THANKS,
If I'm not mistaken mine does have the bigger bolt, and yours should too
2001 Ford Excursion
06 LJ rubicon
post #10 of 10 Old 03-05-2014, 07:44 AM Thread Starter
mine it's smaller bolt, and it's a big problem for me
LIMITED EDITION
ZF6 SWAP
MBRP 4" EXHAUST
DP TUNES
AIS AIR FILTER
Ritch is offline
