stub shaft - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 12 Old 02-20-2014, 07:02 PM Thread Starter
stub shaft
so i fairly certain the stub shaft and bearings are shot. where is the best place to buy one? the dealer only sells it as a kit for 430 bucks. the u joint is 28 bucks at oreilly but they dont sell the shaft.
greasemykey is offline
post #2 of 12 Old 02-20-2014, 07:41 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Ebay... genuine Dana/Spicer parts can be had for reasonable $. I bought a complete kit for both sides that included stub shaft, needle bearing, axle knucle seal, and universal joint. Dont recall the cost but I'm sure it was a lot less than $400+. Maybe $250-$300? For both sides mind you...
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #3 of 12 Old 02-20-2014, 07:49 PM Thread Starter
hmm all i see are the outer ones. i need the inner i think and the bearings. i have a **** ton of play in the axle where it comes out of the axle tube
post #4 of 12 Old 02-21-2014, 02:37 AM
Quoted: 23 Post(s)
You would if the needle bearings are shot. That is the only support for that end of the axle shafts.
Greg
Semper Paratus
post #5 of 12 Old 02-21-2014, 05:12 AM Thread Starter
i can grab onto the u joint and there is no support at all in there i can move it quite a bit. the dust shield is intact though. its just i have this 70mph groan like a wheel bearing but i have replaced both twice now and when i turn to the left you can hear a crunching sound when i am moving. but only when the weight is shifted to the right side.
post #6 of 12 Old 02-21-2014, 11:00 AM
scagle1's Avatar
It has movement when free. Did you replace the wheel bearing or the needle bearing ? Is the shaft ate up where the needle bearing rides against it ? I would say either your needle bearing is shot and needs replaced or the wheel bearing is bad unless your shaft is ate up and eating bearings. I thought I saw something recently where Rockauto had the short shaft for $56 or something like that... Don't take that to the bank , but we just did needle bearings two weeks ago on a friends and I thought he said it was something like that for the shaft which he didn't need.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #7 of 12 Old 02-21-2014, 11:26 AM Thread Starter
the wheel bearings have only about 1000 miles on them. i never looked that the outer stub shaft before i replaced the wheel bearing.
post #8 of 12 Old 02-21-2014, 11:45 AM
scagle1's Avatar
Check your needle bearings as previously stated. You have a seal on the inside of the tube next to the pumpkin , you have the dust seal at the outside of the tube that is usually loose anyway and supports nothing. You have the needle bearing which rides on the outer shaft , you can't miss the needles from the bearing if it's bad or the shaft being ate up if you feel it , you have the wheel bearing which I doubt failed in 1000 miles. I am going off a 4 wheel drive set-up so if 2x setup at the hub is completely different then disregard my over abundance of ignorance -
scagle1 is offline
post #9 of 12 Old 02-21-2014, 12:03 PM Thread Starter
yes it is 4wd. ok so if i pull the wheel bearing out the stub shaft should slide right out or do i have to open the pumpkin and remove any c clips?
post #10 of 12 Old 02-21-2014, 12:17 PM
scagle1's Avatar
I believe they slide right out , at least the passenger side does - might have to work it some. I'd check both sides as the noise can often sound left and be right or vice versa. There is a vacuum seal for the hubs that has to come out I believe before the shaft will come out , will probably trash it so expect to need another , when the new vacuum seal goes in there is a tool to drive it in , we got the last one to seat right by putting it in with the shaft and then Using the wheel bearing assbly hub and a slow torque sequence on the four bolts to pull it in some of the way so it was fully in and then removed the wheel bearing assembly and gently used a mallet and wood to get it fully seated on the stub shaft while in the tube before reinstalling everything.
scagle1 is offline
